Modding Polishing a Firelite
Discussion in 'Modding' started by MrWizard, 16 Apr 2008.
  1. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    So I just scored a 40GB Firelite drive from work. It's pretty much new and it's plug n' play so I'm happy.
    Here's the deal though: It was previously etched, and that's no good for me because I want it to look nice. I removed the top and bottom covers, which I thought were plastic and I was already planning on a simple re-paint. To my surprise, they're actually aluminum :)rock:). So my new plan is to get the halves sanded down and them hit them up with some emery cloth to smooth them out a bit. Then I'm going to hand-polish them to (hopefully, with some patience) a mirror finish. My question to you guys is this: What compounds have you used on aluminum in the past that yielded some nice results? I was leaning toward some mothers billet wheel polish, but if there's a better alternative, by all means pass it on. :dremel:
    I'll post some pics here sometime soon when I'm finished with the little bugger. Thanks in advance, happy modding :thumb:
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    Autosol
  3. Cheapskate
    13 May 2007
    DuPont polishing compound. It has a nice grit to it and will polish faster than Mother's. I've never seen Autosol in the US.
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Colgate sensation whitening
    What? :worried:
  5. mattthegamer463
    26 Nov 2004
    Thats true, toothpaste works well as a polish. Give it a shot I guess, its metal you can't hurt it.
  6. cogitoergosum
    cogitoergosum What's a Dremel?
    14 Jul 2004
    I swear by Mothers Wheel Polish. I use it on my car, my case, my keys(dont ask)..anything I want shiny.
  7. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    Keys?:eyebrow:
    Sorry I just had to. :hehe:
