Poll: Dell reintroduces XP on home PC selection
Discussion in 'Article Discussion' started by The_Pope, 24 Apr 2007.
What OS would you choose for your Dell?
  1. Windows XP
    24 vote(s)
    22.9%
  2. Windows Vista
    25 vote(s)
    23.8%
  3. Linux
    11 vote(s)
    10.5%
  4. Wouldn't buy a Dell
    45 vote(s)
    42.9%
  1. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
  2. DougEdey
    5 Jul 2005
    Don't you just love people that hate change for the better?
  3. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    What was the point in getting rid of it in the first place.
  4. DougEdey
    5 Jul 2005
    XP is being discontinued and Vista (IMO) is a letter better at memory maintenance and overall works better.
  5. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    i would choose vista, i can always install my current copy of XP if i really want to :p
    having played with vista in a VM for a bit the only thing that i really really dislike is the new explorer
    i think its horrible and a far worse file manager than the old XP explorer
    i dislike what they've done with some of the configuration options too (notably network connection config and display properties) but i can live with those being different as i dont have to change them very often
    explorer is something i use all the time
  6. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    Maybe Vista is great on the high end gaming PCs, but isn't it an absolute hog on less well spec'd systems?
    I guess this goes back to the first days of XP.
    I was/am in the boat that refused to switch from Win2k. I only use XP on this laptop because it came with it. And yes, the first thing I did was shut off all the bells and whistles and switch back to classic everything.
    Give me win 3.1 that actually works. :)Ug: change is bad. :grunt:)
    Not having tried Vista, I guess my opinion doesn't mean anything.
    Plus the fact that I'll probably never buy a Dell.
    That being said, I don't need DX10 for anything, so I'd sooner switch to Linux than Vista.
  7. mikeuk2004
    mikeuk2004 What you Looking at Fool!
    3 Sep 2004
    On a a pre built machine from dell then yes to vista. But not for my home diy job as my components are not compatible.
    I think Vista is too power hungry to work well on a laptop.
  8. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
    Seems strange, didn't know the Dell buyin public was savy enough to realise they can't play their games on Vista. Cause, let's be honest, what else does XP do better than Vista?! Still, choice is a good thing.
  9. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    I fail to see how Vista is a change for the better? Microsoft seem to have spent most of the development time building in restrictive DRM, tacking on useless user security features (UAC anyone?) and writing a slug of a GUI.
  10. Buzzons
    Buzzons Minimodder
    21 Jul 2005
  11. DougEdey
    5 Jul 2005
    What Buzzons said.
    But also, the memory management has been a major gripe of mine for ages. I want my RAM to be used not ignored.
  12. quack
    quack Minimodder
    6 Mar 2002
  13. DougEdey
    5 Jul 2005
    Of course UAC isn't foolproof, and I guarantee it will have a huge patch in SP1. But It's better then nothing and to be frank, everything has holes in it, Mac and *nix but Windows' are the most exploited because thats where the users are that can be robbed.
  14. sadffffff
    sadffffff Minimodder
    20 Oct 2003
  15. fargo
    fargo What's a Dremel?
    13 Feb 2006
    sounds like your getting a little cockney over there. us
    dell users don't have to play a game on vista to know
    its not working so well that info is all over the web that is if us dell users can read!!
  16. DougEdey
    5 Jul 2005
    sad6f: was that a QFT or sarcastic quote?
  17. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I wouldn't buy a dell in the first place anyway.
    they re-wire their power supplies and connectors, making upgrades a chore, and often lock out the out of many crucial BIOS settings. (on my older dimension I can't even set the AGP ap to 4x even though the board is capable of it)
    they also rewire the motherboard headers. :wallbash:
  18. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    The problem is that they've now developed windows to such an extent that additional features really feel like frippery. As far as I'm aware the only real big change in Vista is DX10, and I don't really play games even if anyone was insane enough to release a DX10-only game, which they won't for a while yet.
    There are a raft of known driver problems with Vista and it is even more of a resource hog than XP, which was even more of a resource hog than 2000. I rely on Windows PCs to make a living, so really, I have absolutely no reason to go elsewhere until something like After Effects requires it (I only went to XP because Adobe Premiere insisted I did).
    So frankly, why the hell would I want to go anywhere near Vista? What would the advantage be? Lots of instability and bug issues.
    Screw this noise, I'll wait for SP1.
  19. DougEdey
    5 Jul 2005
    The thing is that Dell has one hell of a lot of clout and if Dell say they won't be buying stuff from manufacturers that don't support Vista then drivers will soon be changed over.
    At the moment no-one wants to spend the resource to invest in vista because there isn't market penetration. Dell get most PCs to end users and businesses!
  20. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    I would probably get vista installed for the licence then retro install XP till SP1. I like the idea of a new shiny windows but quite frankly don't trust MS to get it right first (ish) time. Having said that i would probably go with Linux on a laptop any way since its likely to be a non gaming box any way.
Tags: Add Tags
