Cooling pool as reservoir + radiator
Discussion in 'Hardware' started by theflinger, 23 May 2004.
  1. theflinger
    theflinger What's a Dremel?
    21 Mar 2004
    Just looking out onto my nice pool, and was thinking...
    If I could get components that could handle chlorinated water, and I used this setup only when the pool was open, couldn't I just run a hose down to the pool and pump water back up?
    Although it would be a long place to go, the water would never heat up :D
    Imagine having a 60,000 or so gallon reservoir!
    just a dream because I haven't even started a watercooling rig yet..but....thoughts?
  2. czechmodder
    czechmodder What's a Dremel?
    5 May 2004
    1 HUGE problem:
    pools are meant for use in the summer, thus hot weather=hot water. do u really want to be pumping hot water thru your system? not to mention the power of the pump would outweigh any cooling benefits of the pool/res because it would dump so much heat into the water.
  3. keir
    keir S p i t F i r e
    5 Oct 2003
    sounds a bit pointless to me tbh :baby:
  4. Darv
    Darv Bling!!
    12 Aug 2002
  5. Der Me!$ter
    Der Me!$ter What's a Dremel?
    14 Sep 2002
    How would you take that setup to a LAN? :hehe:
    If I had enough time and a pool then I would have probably tried it. But I'm happy with my dual radiator system anyway.
  6. Redimp
    Redimp What's a Dremel?
    16 Aug 2003
    What if someone peed in the pool? :D
    Maybe you'd be better off hooking your pc to your cold water tank?
  7. theflinger
    21 Mar 2004
    the water in my pool never gets above 80 F, so I am not sure that that is a problem :)
    but yeah it's incredibly impractical, the cold water tank has promise :D
  8. Mr.Nonflex
    Mr.Nonflex What's a Dremel?
    2 Jun 2004
    the water in the pool is in contact with the open air, thus dust and dirt can get into the pool and get in to your waterblocks and pomp. :duh:
  9. samcat
    samcat What's a Dremel?
    11 Nov 2002
    Submerge a rad in the pool... So its cooled by the water in the pool. Ideally you would mount it over a pump inlet/outlet (prob outlet so it doesnt get clogged). This eliminates the problems chlorinated water would case with the copper... SO long as the outside of the radiator is nicely painted/anodized.
    Have always thought it would be neat to mount a rad in a stream/fresh spring... Waters almost always cold, constant flow etc :)
    CYa
    S<a C
  10. theflinger
    21 Mar 2004
    I would obviously put a filter on my "pomp"
  11. r3Q
    r3Q Minimodder
    31 Jul 2002
    now that sounds like a good idea. i would go ahead and give that a try... OO if you live in a climate that is almost always cold outside, just put your rad in the snow somewhere =) ^_^
    throw it out the window when it gets cold... heheh.. ACTUALLY. mount the rad+fans outdoors or somthing!!! that would be sweet. cold air+airflow=coooold water! :rock:
    have fun tho
  12. warrmr
    warrmr What's a Dremel?
    5 Nov 2003
    i cant remember where i saw it but there was this guy who modded a fire extinguisher to use as a res. basicly he used the part where the hose screws onto as the inlet/outlet once he sealed it all up. and dug a hole in the ground and burried(sp?) the res 2 meters underground and the pipes wer ran up the side of the house anlong a shaded wall (alwase in shade ) to his room.
    if i remember right it was a dual pump setup one pumped from the res up the wall and the seccond was to boost the perssure once it got to his puter. the only prob was that he had to insualte his pc cos the water was cooler than ambient room temp.
    oops sorry i dug up a old thread i jus noticed last post date :O damn related thread function
  13. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I remember reading in an early CustomPC or PCExtreme (I can't remember which) about a guy
    who, for his rad, installed a huge loop of tubing under his garden, below the point where temps
    remain constant no matter what the time of year.
  14. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    hexus i think.
    oh look here we go
  15. LAGMonkey
    LAGMonkey Group 7 error
    4 Aug 2004
    Yea i remember reading that one. Was a lot more work than just trowing the rad outside in the snow :D . The was to do is to get a rad and immerse that in somthing like snow or water. hell you could always bung it in a fridge but then you may as well get a phase change setup.
    Anyone remember the BONG cooler? its on some website but i cant find it atm.
  16. warrmr
    5 Nov 2003
    wasnt that made by some guy over on OCS (now leathal hardware) im sure bindi or lucifer (if hes still around) can shed some light on who that was http://www.lethalhardware.com/
    Edit link fixed
  17. LAGMonkey
    4 Aug 2004
    404 on the link there. :confused:
    But im sure that name rings a bell. But you could just scale the idea up and use a shower if needs be :D now wouldnt that be a talking point...
    "hunny...dont use the shower, im trying to play Doom3" :hip:
  18. Firehed
    15 Feb 2004
    I thought of doing this at one point but decided not to for a few reasons:
    It would probably ruin the waterblocks
    You would need a pump with a LOT of power (at least for me, I'm on the second floor)
    I don't have a pool
    You'd get crap in the pump. And if you filter it, you would need to change the filter really often
    But on the plus side, you wouldn't need to hear any of it since the pump would be outside and the SA of a pool is a whole lot more than any reasonably sized rad could give you (i.e. the pool is the rad).
    And you get a free heated pool, if you're running a prescott.
  19. Simonsnet
    Simonsnet What's a Dremel?
    25 Jun 2004
    there was indeed the dude with a fire extinguisher. But there was also the dude with a ruddy great hot water tank that he'd used 10 metres underground. It was about 10 times the size and worked great!
    When I've eventually finished uni and got my own place, I am DEFINITELY going to do that!
  20. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    i do that....
    i have my BIX on my windowsill :D
    works great in winter, get sub 30C temps in almost complete silence :)
    not so good in summer, i usually bring it inside during the day to keep it out of the sun (damn sun, why cant i just feck off :p)
