Pop goes the Psu...
Discussion in 'Hardware' started by StephenK, 24 Feb 2007.
  1. StephenK
    StephenK Sneak 'em Upper
    21 Dec 2006
    Hi all,
    A few mins ago I plugged my pc in. As i plugged the psu plug into the wall socket there was a pop to my left from inside my case.
    The mobo light was on so i turned on the pc. The fan in my psu was making an odd noise. Not very loud but the sound of a tiny lawnmower (a sort of rata-tata-tata-tata-).
    My brother and I took a look with the machine off, we tried moving the fan and it moved fine. We turned on the machine again, same noise, so he tried slowing the fan using a small tool he had. After this the sound was pretty much gone.
    Any ideas on what the POP! was? Need I be concerned or was it a minor power surge or something?
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    if you got a multi-meter check the voltages via the molex connectors, with the 12v and 5v lines are ok, then the psu could be ok.
    other than taking the PSU apart and having a good look, i cant say any more.
    If you are that worried, RMA the PSU
  3. Jipa
    5 Feb 2004
    There's sometimes POPs when the plug isn't all the way in and there's a tiny arc between the connectors. Though I have totally no idea why the fan went lawnmower! Maybe it just decided to break it's bearings at that very second..
  4. StephenK
    21 Dec 2006
    All seems well here. No more noise or popping. I shall be keeping a close eye (or an ear) on it though. Thanks for the info guys :)
  5. dimebar
    dimebar What's a Dremel?
    26 Jul 2003
    be carefull, it is possible a inductor or capacitor blew, and bits were touching the fan, was there any sort of smell after it happened. if you can u need to have it tested to make sure ripple voltages are ok, otherwise it could harm the rest of u rig. if it is old and out of warenty open it up andd have a look, ( be carefull of harmfull voltages etc...) or contact the manufacturer for support.
  6. Masterchief
    Masterchief Banned
    23 Feb 2007
    this should be in tech support
