Hi everyone I'm developing a website (http://www.thealligatoronline.com) where I want a 'most popular' box. You can see it on the homepage by scrolling down about halfway. Every time someone loads a page, the server stores the page address ('page') and a timestamp ('datetime') in a database. The SQL query to work out the popularity is Code: SELECT page, COUNT(page) AS hits, SUM(POW(1.1,(datetime-NOW())/86400)) AS popularity FROM stats_table WHERE page LIKE 'article/%' GROUP BY page ORDER BY hits DESC LIMIT 0,10 As you can see, the popularity index for each page is SUMviews( 1.1-{age of each view in days} ) However, this doesn't work very well. It gives too much preference to recent hits. I could replace 1.1 with a lower number, and keep tweaking until it's right, or I could ask everyone here for a different idea altogether! So, what would you do to calculate popularity? Thanks! ch424
Your query doesn't appear to actually have the views in the popularity algorithm, unless you're doing the math for it somewhere else.
SELECT page, COUNT(page) AS hits, It's that. Every time a page is viewed another row is inserted. (Caveat: this table will get biiiiiiiig for a large site). You're probably better off using a different method of tracking.
It's not as simple as I first said though - the database also stores the referrer. It needs to store each hit as a row, along with user and referrer data because when the site gets bigger, I eventually want to do 'you may also be interested in' like last.fm does. I know the last.fm/audioscrobbler database is actually just text files, and they write their own analysing software, rather than using a SQL database. At the moment (a few thousand rows in the table) that query takes 0.002 seconds to execute, so there are no size worries. When execution time gets longer, I'll just cache the results and only calculate every 5 minutes or whatever. capnPedro, thanks for that idea. I've given it a go and will see how well it works!
