Modding port extenders?
Discussion in 'Modding' started by Cowcharge, 22 Feb 2005.
  1. Cowcharge
    Cowcharge What's a Dremel?
    27 Jan 2005
    Hiya all,
    I'm trying to find extenders for various ports like monitor, usb, keyboard etc., as my mobo is going to be a couple of feet away from where I'd like all my ports to be... I'm going through all the modding links, but does anyone know where I can get them?
    Thanks,
    Cow
  2. Springs
    Springs Boing boing
    29 Aug 2004
    try your local computer shops either online or in the city.. most of them aint hard to find..
  3. Cowcharge
    27 Jan 2005
    Haven't found a single one yet, that's why I asked, LOL
  4. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Extension cord?
  5. Springs
    Springs Boing boing
    29 Aug 2004
  6. Cowcharge
    27 Jan 2005
    I'll check 'em out, thanks!
  7. adamjones01101
    adamjones01101 What's a Dremel?
    29 Jul 2004
    Check out www.jameco.com they have just about any kind of extension cable you could possibly need.
  8. fizban
    fizban What's a Dremel?
    11 Jun 2004
    Cyber Guys usually has stuff like that too!
    Oh and out of curiosity what'cha doing with em?
    -Fiz
  9. nick01
    nick01 What's a Dremel?
    6 Nov 2004
  10. Firehed
    15 Feb 2004
    If all else fails you could desolder the plugs on the mobo and add in your own extension wires. Just don't screw up if you try it :thumb:
  11. Emon
    14 Jun 2004
    You didn't shield it correctly then. I've used 10' VGA extension cables, both shielded, one had a ferrite and a copper braid, one had just a copper braid. They both gave me a perfectly clear picture on 1280x1024@60Hz.
