I need to buy one of these for my trip to Australia later this year. I know you can get MP3 players but I won’t be near any PC’s where I’m going Anybody got one? Any recommendations, I’ve seen a couple on Amazon, Diamond Rio Volt £149.00! bit on the expensive side Under a hundred quit is my budget, just in case a break or loose it on the trip.
www.scan.co.uk :- http://web6.scan.co.uk/productinfo.asp?wpid=5627 Napa DAV311 Portable MP3 VCD CD Player (CDRW Compatible) £79.90 (inc VAT) (+£10 delivery) ~= £90
nice specs too... NAPA DAV311 is a new revolutionary product available in the market.DAV311 the all-in one portable MP3/ VCD/ CD-DA player. It supports MP3 CDs as well as ordinary audio CDs and is compatible with the CD-DA,VCD(MPEG1),CD-R and CD-RW.Compact size,light weight, and really affordable price make it the best and versatile CD-DA Player out there. NAPA DAV311 is able to recognize and play multi-session CD-DA. A multi-session CD-DA is a data CD to which data is added incrementally in more than one session, allowing you to periodically add and update files and folders to your CD-DA.NAPA DAV311 has the greatest compatibility with most brands of CD-R/RW disc . We have tested most of the well-known brands of CDRW and verified that they are able to be recognized and played by our DAV311. NAPA DAV 311 supports programmable playback. Its built-in programming features allows you to select up to 20 of your favorite song titles and store them in a desired equence.You can store any track more than once if you wish to. Key Features MP3, CD, VCD1.0/2.0 disc playback. CD / MP3 with 45 / 30 seconds Anti-shock function. 2 x 2A Re-chargeable Battery Function status On screen display at VCD playback Extra Bass-1 / Bass-2 EQ mode Key hold 25 steps Digital Volume control Infra-Red Remote control Song Repeat one / Repeat All / Random selectable Song Programming Song tracking Fast forward / backward Sony Mechanism Specification Playable Disc Type MP3 , CD-DA, Video CD V1.0/2.0 Other Media Playable CD-R CD-RW DIGITAL VOLUMN CONTROL 25 steps AUDIO FREQUENCY RANGE 20 ~ 20 kHz MAXIMUM OUTPUT > 5mW (32 Ohms) SIGNAL TO NOISE RATIO > 85 dB TOTAL HARMONIC DISTORTION < 0.1% AUDIO OUTPUT Ear-phone jack Video OUTPUT Video Line-out jack OPERATING TIME 3-5 hours (MP3/128kbps or VCD / Alkaline Type) 5-8 hours (CD-DA with ESP / Alkaline Type) 7-10 hours (CD-DA without ESP/Alkaline Type) Box Contents One NAPA DAV311 portable digital audio CD player Stereo Earphones Remote control User's Manual 2 x AA Rechargeable Battery AC/DC adaptor Video & Audio cable
The first One? This was one of the first players I saw. I then went off and read a few reviews and while they are cheap the sound is poor. Someone said they had a hiss noise? Don't like the sound of that. Apart from that it has nearly all the specs apart from a tarty in line controller, not sure what you'd use a remote one for when your on the move.
