Education Portable/mobile phone charger
Discussion in 'General' started by Kronos, 7 Apr 2016.
  1. Shirty
    18 Apr 1982
    I got the OnePlus power bank off Gearbest for about a tenner and it's brilliant, but I'm sure others with the same rating are just as good.
    Just wanted the one which matches my phone ;)
    Took about 10 days to arrive.
  2. Kronos
    Kronos Multimodder
    6 Nov 2009
  3. Atomic
    Atomic Gerwaff
    6 May 2002
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    That is useful information as I have a couple of them laying around doing nothing.
  5. Xir
    Xir Modder
    26 Apr 2006
    My powerbank, (tiny as it is) died because carrying it around with the cable plugged in broke the connector.
    I really only need it when using the phone as a satnav (cause that drains the battery quite fast).
    So how do you guys avoid this? I mean, if I need to put it on a table and not touch it to recharge I might as well recharge it properly, the powerbank is for carrying around, for in-pocket-recharging. :confused:
  6. monkeyville
    monkeyville Evilish Monkey ++;
    3 Aug 2003
    The oneplus powerbank has been great for me.
  7. Herbicide
    Herbicide Lurktacular
    27 May 2004
    I've had no trouble with my older-model EasyAcc 10Ah power bank.
  8. wolfticket
    19 Apr 2008
    I've never had any trouble with anything that has lots of decent review on Amazon. My last couple have been "Swees" branded as I've found (probably due to them being cheap and lacking some of the more advanced features and protection) they handle powering non-phone devices well.
    I have a little cheap inline USB voltage/amperage meter (something I'd recommend) and the voltage has typically been within specifications (4.75-5.25V as I recall) with most cheap banks I've bought off Amazon, and the speed of charging (amps) appears typically much more dependant upon the cable and device than the charger (within the specifications of the output on the power bank at least).
    I think a lot of people use power banks as a portable charging station of sorts rather than commonly using their phone while connected to it on a regular basis. If you find the output on the bank breaks often because of this then maybe a one with a short built in cable in addition to a normal output would be good from a durability and portability pov: http://www.amazon.co.uk/s/ref=nb_sb...s=aps&field-keywords=powerbank+built+in+cable
  9. Herbicide
    27 May 2004
    Swees, you say? I'll just leave this here. *wanders off, muttering about a lack of protection, all right...*
  10. wolfticket
    19 Apr 2008
    :worried:
    I'm much more picky about my mains to usb power supplies. I basically only ones made by large reputable manufacturers.
  11. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
  12. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    I use one of these:
    https://www.amazon.co.uk/dp/B01422TC14?psc=1
    At 20,000 mah capacity I can use it to charge mine and my wife's phone for a week if absolutely needed and they are not expensive at all. Takes a while to recharge, not really surprising given its capacity but holds the charge for months.
