Hi ! I started to reproduce a Portal Turret on SolidWorks I only made the body during "nap mode" but I don't know how-to build the case : Maybe with fiber do you have some advices or ideas ? Does 2 layers of fiber are enough ? The dimensions are : Height : 546mm ; Width : 220m ; Depth : 309mm The "eye-fan" is a 70mm and the sides fans are standard 80mm. I'll put a mini-ITS motherboard with a slim optical drive slot-in and a WD 500GB 3.5" HDD. The CPU cooler should be a Zalman (67mm high) and the CPU a Pentium e5200. The "eye-fan" will flash with the sound, like the turret eye. I'll hide the fans on the left and the right with white wire netting. Bye. Montspy. PS: Is the form factor looks good or is that too much flat ?
Wait 2 months for Geno to finish his, and all your questions should be answered. -You are leaving out a lot of details. Are you talking about carbon fiber, or fiberglass?
I think that I should use fiberglass because it's cheaper than carbon fiber and I don't need a low-weighted shell. The resin (?) will be epoxy resin (?) polyester smell very bad and it's not very solid when it's dry. Sorry for the details but I'm not very good in English so I don't know lots of technical word about modding. Thanks for the indication (Geno's mod). Bye. Montspy.
