poss faulty hdd?
Discussion in 'Tech Support' started by Enforcer, 8 Feb 2007.
  1. Enforcer
    Enforcer What's a Dremel?
    12 Nov 2004
    I'm pretty sure its going. but you can advs me if its not.
    I have a WD 200gb hdd use as a slave (store all me stuff on there, except windows).
    For some reason when it's powered my main drive (c) doesnt want to load.
    When it does load (after several reboots & and a quick beatdown with my boot) it will shut windows down with an error. I believe it was a Redudency cylce prob. I forgot to get a snap.
    Could it be that the slave is going? Would really really suck cause i have SOOOO much stuff i need on there.
  2. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    take disk out, freeze disk, put disk back in, try?
  3. Enforcer
    12 Nov 2004
    So just take the hdd and put it in a ziplock bag and toss it (by toss i mean gently place it in the freezer) and leave it there for 2 - 3 hrs and then stick it back in the pc?
    That cant be healthy!
    K now once its done whats the fastest way to move 180gbs of data to another hdd in the least amount of time?
  4. krimson
    krimson What's a Dremel?
    16 Nov 2006
    also i have heard some success stories of people dropping their drives squarely on a flat surface from like a foot or two (seriously)
    it apparently frees up the needles or something... but, i guess this is only for a hardware malfuntion
    maybe your C drive is to blame. try using a spare hd as a master, or try using only the 200gb and a live linux cd.
    try a different IDE/SATA cable. try an alternate power plug/PSU.
    unplug ANY unimportant devices (like cdrom, fans, floppy, CCFLs, etc)
    sometimes its not the specific device failing, but other things attributing to it
  5. Enforcer
    12 Nov 2004
    surpisingly freezing the hdd worked! i also before freezing it dropped it on a flat surfce apprx 1in off my desk 2 times. boots up, just need to get my new pc to move all my files over.
    thx guys
