Modding Possible to use digital picture frame as monitor?
Discussion in 'Modding' started by TMan7000, 2 May 2008.
  1. TMan7000
    TMan7000 What's a Dremel?
    1 May 2008
    I was wondering if anyone had an idea as to how I could use a commercial digital picture frame as an additional monitor that I could use specifically for chat or watching a movie while I work on a paper. I want a screen that is relatively small and it seems as though it would be cheaper to buy one of these rather than an LCD designed to be implemented in a car. I did search for something like this and have googled this several times to no avail. Any help or input would be greatly appreciated.
    Thanks,
    TMan
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i don't think that picture frames have the necessary inputs to connect them to a computer. even if you could hack a vga input, the refresh rate would be too slow to watch a movie.
    just go pick up an old 17" for $100 on ebay. dual screens are awesome.
  3. TMan7000
    1 May 2008
    Okay thanks....I was just thinking there might have been a way...I don't really have room for a 17" so I was trying to find another solution.
  4. swift_wraith
    swift_wraith I love you Pig.
    3 Mar 2008
    if its a small screen you're after try an old psONE monitor. You can pick them up for about £20 off ebay and they can be easily modded to link to a pc.
    Am thinking small screen due to you asking about picture frame screens. They're usually small and about the same size as a psONE screen
  5. TMan7000
    1 May 2008
    Okay thanks alot, that sounds like exactly what I need.
  6. W-fault
    W-fault Otherwise known as widefault
    16 Mar 2008
    A few of the LCD picture frames I've taken apart could take a composite(yellow RCA) or S-video input with a bit of modding. Somewhere in my pile of parts is a 7" ADS screen that runs s-video from the board with the jpeg decoder to the screen itself. Always toyed with putting in a jack and a switch, but the uses would be pretty limited for me. Quality would be poor for text since you'd be stuck with using a TV out, but videos or movies probably would be OK. Most of the current crop of LCD frames have the ability to play mpeg movies as well as show pictures.
  7. TMan7000
    1 May 2008
    Okay, that sounds a bit promising.....It doesn't sound like I am going to be able to read text from it but it would work as a screen for viewing a web cam which is a plus. I think if I used a PlayStation LCD, I would have the same problem with text...
  8. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    What brands have you taken apart W-fault?
    It would be awesome to know which ones do have & don't have the video connection inside!
  9. W-fault
    16 Mar 2008
    I've had my hands on a few broken ones, mostly the unbranded, virus-loaded, made in china ones. I noticed some of them had a separate AV output, so I ripped them apart to see where it was coming from. On the ADS screen there's a cable running from the decoder to the LCD board, and the board also runs that signal to the AV output unmodified. Most that have the AV out have some variation on that setup, although if there's a single board inside it gets much harder to inject a new signal. Should pull the ADS out and take pictures this time.
  10. mvagusta
    24 Dec 2006
    sounds awesome!
  11. swift_wraith
    3 Mar 2008
  12. TMan7000
    1 May 2008
    Thanks for that, I had found that tutorial earlier but based on some of the previous discussion, I'm not sure how good text will look on there...What is your experience? I was also trying to find something that might be a little cheaper and I didn't really want to have to use ebay. Thanks for the links though, those are great if that is what I decide to do :)
  13. keith.t
    keith.t What's a Dremel?
    30 May 2008
    dont they have slower refresh rates ?
  14. TMan7000
    1 May 2008
    That is what someone already said....:eyebrow:
  15. mushky
    mushky gimme snails
    24 Mar 2003
    Does anyone have the measurements of the psone screen? Thinking about hacking one into front of my case
  16. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    It's amazing to me that no one has made a 640x480 screen that fits into say 2 or 3 5.25 bays as a drop-in product.
  17. TrowthePlow
    TrowthePlow What's a Dremel?
    12 Nov 2008
    Personal Experience
    The closest I have seen is the Thermaltake 7" LCD Screen. I personally have used a car headrest monitor and some 1/2" Acrylic to make a 3-Bay LCD screen. The only oddity I have is that it has to be off when I turn on the computer, then I enable it in NVIDIA Control Panel, then I can turn it on, but can't adjust the resolution. Whatever, it works :) I got mine off Ebay for around $25, plus 5 for shipping.
  18. Acolyte
    Acolyte What's a Dremel?
    23 Aug 2008
    I'm sure I've seen LCD picture frames with composite video inputs which don't require any modding/dismantling. Google might be your friend here.
  19. jhanlon303
    7 Sep 2006
  20. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
