Other Possibly NSFW: Should I pop this blister?
Discussion in 'General' started by longweight, 15 May 2013.
  1. Throbbi
    Throbbi What's a Dremel?
    10 Sep 2009
    Pop it, take off all the skin, dump foot in vinegar all whilst filming = instant youtube millionaire! (maybe :worried: )
    Seriously though, I get a lot of blisters (there's some bizarre condition with my feet, all I get from Doctors after 25 years is a shrug :lol:) and I always do a pop as described by Lance using a sterilised needle and then a simple blister plaster with a small dab of Savlon on it. Works every time.
  2. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    Just pierce it with my wit.
    *Hair flick*
  3. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    In the sprite of bit-tech this should be modded with a dremel, so find an engraving bit and mash it up!
    lol!
    lp rob1 likes this.
  4. longweight
    7 May 2011
    I will definitely film it being popped!
  5. kingred
    kingred Surfacing sucks!
    27 Mar 2008
    Drink the fluid from the blister and I'll give you rep.
  6. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    As a military bloke, I can highly recommend zinc oxide tape for blister prevention, or for covering blisters if you have to wear the footwear again that caused the blisters in the first place. There's also a 'spray on skin' from 3M that, should the blister burst and the skin become loose, will create a protective barrier and prevent infection developing inside sweaty boots, which you then zinc oxide tape over while you're wearing the offending footwear and remove when you're not to let the skin breathe.
  7. longweight
    7 May 2011
    Thanks guys!
  8. longweight
    7 May 2011
    Popped! Had to cut it with some nail scissors so that the fluid could actually get out!
    Going to leave it without a cover for a few hours to try and dry it out a bit.
  9. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Where's the footage?
  10. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Seconding this. If you don't have zinc oxide tape handy you can mimic it with a little dab of antibiotic ointment and something to cover the area. Bandaid, moleskin, duct tape... Keeps the skin from rubbing and making things worse.
  11. longweight
    7 May 2011
    I have some "wound" dressings and tape plus some antibacterial cream.
    I will get some proper stuff tomorrow morning.
  12. chris182
    chris182 What's a Dremel?
    6 May 2011
    Electrical tape's almost the same right...
  13. Cei
    Cei pew pew pew
    22 Mar 2008
    I hope you sterilised those nail scissors...
  14. longweight
    7 May 2011
    Nice bit of warm soapy water :)
  15. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I used to get blisters constantly from playing 5-a-side football. I tried all sorts to prevent them and gave some metasox a try. I don't know what it is about the sock but they are about the only thing I can wear for football and end up with 0 blisters. You can buy normal sock size ones so you don't have to buy the football sock length ones but I'd highly recommend them if you think this might be something you'll start to suffer from.
  16. Cei
    Cei pew pew pew
    22 Mar 2008
    ...That's about as close as to sterilisation as throwing it on the floor. Next time, boiling water for a minute, or some vodka.
  17. jinq-sea
    15 Oct 2012
    My usual sterilising method is heating it up 'til it glows. Or meths. Or both. But once it's cooled down...
  18. Cei
    Cei pew pew pew
    22 Mar 2008
    Yeah, heating up works if the item will take the flame without being damaged.
    My preferred method is an autoclave, but is pretty hard to do outside a hospital.
  19. longweight
    7 May 2011
    It went wrong and my foot fell off.
  20. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    My condolences man :( Wear it round your neck on a piece of string :)
