Linux Post your Linux desktop
Discussion in 'Software' started by JuMpErFLY, 3 Jul 2006.
  1. Glider
    Glider /dev/null
    2 Aug 2005
    Yep, that's Conky. And not only does it look cool, it's usefull ;) and unlike Samurize or any other system monitors out there also very light (1-3% CPU on my system, with a huge varable conky config)
  2. Shielder
    Shielder Live long & prosper!
    26 Jul 2007
    Hmmm, I wonder if I'll be able to get it going under Fedora/Red Hat. :D
    Andy
  3. Nexxo
    Nexxo Rotate Your Owl For Science
    23 Oct 2001
    Samurize is light: 3-6% depending on what trickery you do. Graphic-heavy plug-ins (custom-made analog dials made by rotating .jpg images, for instance) can push up the load a bit, but otherwise even a very big config comes in at about 3%.
  4. Glider
    Glider /dev/null
    2 Aug 2005
    But I am talking on my system... In 'rest' my CPU throttles to 600MHz, and then it's only 3%, at full speed it's 1%.
    I used Samurize when I was on Windows, and it was a lot heavier... But I reckon that's due to the nature... Conky config == Plain txt file, Samurize is a more graphical thing...
  5. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    here is my conky config file if you want it. With conky, you can display almost everything if you know how. The man page is almost complete for that, but there is few hidden feature/newer than man page and it is possible to use some hack do display other things (using the file monitor and few bash/c/c++ script/simple apps)
  6. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    conky?
  7. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    Conky is the system monitor at the top.
  8. Shielder
    26 Jul 2007
    Couldn't get conky compiled on Fedora. Didn't have the time available to do it, so I gave up (for now). I'll try again at the weekend.
    Andy
  9. Elv13
    26 Apr 2006
    just find an rpm, or post the error here, it is propably not a big problem.
  10. MrMichaelHill
    MrMichaelHill What's a Dremel?
    25 Jun 2011
    My first post here on the forums...
    Hello everyone!
    Intel Core 2 Quad 2.4GHz
    4GB DDR
    Nvidia GTS450 1GB
    250GB SATA2 - Ubuntu 11.04 (64)
    500GB SATA2 - Windows 7 (64)
