I can't rate what I can't see derrr. Nice cold cathode. I think me wants a window case. But which one. Thermaltake? Lian Li? Cooler Master? Uggh nice looking though
I built this comp 2 months ago. I rewired all the cables EDIT: Shadowed_fury, My case is not lian li. Its Kingwin 424 I got the case at Bestbuy
Very nice, this is what I call a good work! Why don't you stealth the DVD burner and memory reader? That way it would look completely clean, oh, remove the Asus sticker too.
On a build I did a while back I mounted the HDD backwards, allowing me to route both the power cable and data cable completely out of sight.
Ok, if this is about rating our wiring... I'd like to think I made a pretty clean job of it this time around. If I ever get around to putting in a window, it won't expose the bottom area, though I'd hardly call it messy.
Looks great! Honestly looks better then before (NOT an easy thing to do!) since you now focus on the cleanliness of the mobo and don't notice anything to your right besides a clean HDD. Glad I could help. $5.
Thanks You've got a nice clean setup too. I'd never dare rewiring the ATX plugs and everything with a single color wire, though it looks a treat. Aside from the fact that I couldn't stand soldering that much stuff, I'd be a bit too concerned about frying something. That, of course, coming form someone who hung up an electronic audio visualizer by a metal shower hook while it was running.
When I first saw the picture, I thought you were faking, and just hadnt hooked up any of the cables because it is so clean. Then I looked closer and saw the plugs going into the mobo, and the cables going behind. Very very nice job on the case, definately a 10/10. Also, the reversed harddrive idea is a great idea.
