Posting issues
Discussion in 'Feedback & Suggestions' started by goldstar0011, 23 Mar 2017.
  1. goldstar0011
    goldstar0011 Well-Known Member
    2 Sep 2007
    When I try to post I keep getting the below message but when I try again straight after it allows me
  2. goldstar0011
    2 Sep 2007
    Is anyone else getting this?!
    I just typed a long post and lost it because of this!
  3. MadGinga
    MadGinga oooh whats this do?
    19 Mar 2009
    I've seen this a number of times, only when trying to start a new thread (in the MP) - very annoying.
  4. goldstar0011
    2 Sep 2007
    And again!
    Gladly I saved copied the message I was posting
  5. MLyons
    MLyons Half dev, Half doge. Staff Administrator Super Moderator Moderator
    3 Mar 2017
    What browser are you using? Any plugins etc installed?
  6. goldstar0011
    2 Sep 2007
    IE11, no plugins, at work
    but....
    I don't recall having this issue at home but I don't post loads, let me try
    It's still happening and making posting unpleasant :(
  7. MLyons
    3 Mar 2017
    Is it happening at work and at home? I'll have a quick look and see if there's anything i can do. If not I'll speak to a colleague about it. If anyone else if having the issue post below.
  8. goldstar0011
    2 Sep 2007
    Test post
  9. goldstar0011
    2 Sep 2007
    ha....hummm...posting at home worked ok
  10. Vault-Tec
    30 Aug 2015
    Yup I'm out today on wifi and just got the same. Also using a MacBook with Safari, if that has anything to do with it.
