Graphics Potentially dead graphics card
Discussion in 'Hardware' started by Nedsbeds, 5 May 2014.
  1. Nedsbeds
    Nedsbeds Badger, Slime, Weasel!!
    16 May 2002
    Hi Bit-tech. Long time since I've posted here, but glad to see things on the up again!
    I've got a potentially dead xfx hd6850 and was just looking to see if anyone else had seen these symptoms.
    It was working fine yesterday but when I tried to turn it on this morning not a lot happened display wise.
    Occasionally I do get something out of the display but there is corruption from the very first bios screen.
    and then it will occasionally boot in to a windows 8 recovery screen. The bootup scans report no issues but after about 3 minutes the display just starts flickering and then dies.
    so, 1st of all, is this a display card issue (I don't currently have the means to test in another machine or another card to test in the PC. I should be able to get access to a psu to test that soon)
    secondly, since this seems pretty likely to be a display issue due to the corruption even in the bios, what is a good replacement these days for an hd6850?!
    Bios information screen
    Windows 8 booting
    Windows 8 recovery screen
    Specs:
    Core i5-760 2.80GHz
    XFX R6850 HD
    CORSAIR DDR3 1600MHz 16GB
    GIGABYTE S1156 Intel P55
    Thanks
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Do you have a spare GPU to test in the system to confirm a fault with the 6850?
  3. Nedsbeds
    16 May 2002
    I don't. Currently trying to obtain a test card...
  4. Parge
    16 Jul 2010
    I can tell you right now, that is definitely a dead GPU. 99% certain.
  5. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    bake it :D
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    do you have a different monitor you can test on, as it may just be that and not the gpu
  7. TheMadDutchDude
    23 Aug 2013
    That's definitely a dead GPU.
    XFX too... yeah, dead. :(
  8. Nedsbeds
    16 May 2002
    Ok guys, thanks for confirming my fears.
    So, the question now is, what is going to be a decent replacement?
    Monitor wise I'm using a dell u2711 (2560x1440) over dual-dvi as well as another 19" dell in portrait also over dvi.
    I don't spend a lot of time gaming any more so I'm not looking to spend hundreds and it would be nice to have something quiet.
    Should I be looking at modern low end, low power eg http://www.ebuyer.com/616903-zotac-geforce-gtx-750-ti-2gb-oc-4-outputs-w-g-sync-zt-70602-10m or slightly older and further up the scale?
  9. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Definitely dead or about to die. You could bake it but that is a last ditch effort that may or may not work.
    Do you game on this rig? If not, any low end GPU will work. A 750ti is a pretty good bet I think.
  10. Nedsbeds
    16 May 2002
    I game very little (the last game I bought on PC was deus ex hr. Basically I don't want a downgrade from the hd6850. That did everything I needed it to
  11. Blogins
    3 Aug 2010
    Please stop suggesting baking broken cards when there's scope for a refund or replacement! :D
    Have a read of my signature thread Nedsbeds as you might be covered by UK consumer law. Not as exciting as baking a circuit board but probably more effective!
  12. Darkwisdom
    27 Aug 2011
    Good point Blogins. It won't be in warranty; but what else could he do?
  13. Blogins
    3 Aug 2010
    Use the Sale of Goods Act to argue the case with the retailer. If the card cost £100 or over and it was bought on a credit card, Section 75 gives equal liability to the credit card company. Failures of this sort are not uncommon with graphics cards so a convincing argument can be made in your favour assuming it was well maintained in the owners care.
  14. bartiszon
    bartiszon Minimodder
    25 Aug 2010
    Suggested above a gtx 750ti might not be a 'speed demon', but is much faster than a hd6850:
    AnandTech Bench
    For instance an EVGA GTX 750 SC (factory overclocked version and nearly as fast as a reference 750Ti) is imho very nice and sexy looking card. It's based on Maxwell, has a DisplayPort 1.2, is 4K monitor ready and it doesn't cost an arm and a leg.
  15. Nedsbeds
    16 May 2002
    Interesting, I was under the impression the sale of goods act was three years (my card being 4 years old)
    Nice to know it is 6
    I'm well aware of the baking solution, but would rather just have a reliable GPU rather than one that could potentially fail in another 8 months.
    I might throw Dabs an email and see what they say.
  16. Blogins
    3 Aug 2010
    Use one of the template letters in my thread and just plainly state the facts without getting emotive about it. Like I said, assuming you took good care of the card in a well ventilated case then argue graphics cards can and do fail over an extended period of time. As you've owned the card for over 6 months the onus is upon you to prove the card was inherently faulty when purchased!
    Certainly does no harm to see how dabs respond! What was the original value of the 6850 and did you buy it on a credit card? If the answer is yes and it cost £100 or over then that opens up further options.
  17. Cei
    Cei pew pew pew
    22 Mar 2008
    6 years is the absolute maximum. However, each product is judged on how long it would be reasonably expected to last. Something like a mobile phone you can argue it should at a minimum last the length of its contract, but a TV should last the full six. Something like a GPU I'd argue should also be in to the longer end of things.
  18. Nedsbeds
    16 May 2002
    According to the invoice it was £135 and yes it was on a credit card. So what is a realistic outcome? Replacement doesn't seem like an option (dabs don't list any 6850s anymore)
    N17 dizzi likes this.
  19. Darkwisdom
    27 Aug 2011
    It is possible they'll supply you with an equivalent replacement. Blogins would probably know.
  20. Blogins
    3 Aug 2010
    Assuming they accept responsibility under the Sale of Goods Act (SOGA) then realistically you'll be looking at a partial refund or replacement of equivalent specification. If a refund is offered then the use you've had out of the 6850 would be taken into account. Typically the 6 year limit of the SOGA is treated as the standard life expectancy. So in your case the equations would go...
    £135 divide by 6 years = £22.50 per year
    6 years life expectancy of 6850 minus 4 years of use = 2 years of non use due to fault
    Multiply the two together for a partial refund of £45! I'd imagine there's 'months' to take into account as well however so run the numbers from the date it failed. If your lucky they might send a card of greater specification. Let us know how you get on anyway and if dabs don't want to know then you can always pursue Section 75 with the credit card company assuming you routinely pay it off!
