Power buttons
Discussion in 'Hardware' started by Hitman, 23 Oct 2002.
  1. Hitman
    Hitman Minimodder
    18 Oct 2002
    Im making a case for the MP3 player Im building, and I need a power button for it.
    The only spare case I have laying around is an old 486, will the power button work from that?
  2. KevinOwns
    KevinOwns What's a Dremel?
    13 Jan 2002
    The 486 is most likely has an AT power supply, which means the switch is not momentary like on ATX. I don't think you would have much luck using it, as if your mp3 player has an ATX PSU and mobo you will need a momentary switch.
  3. Hitman
    Hitman Minimodder
    18 Oct 2002
    Yeah it does have an ATX PSU and motherboard.
    Where can I get a momentary switch?
  4. KevinOwns
    13 Jan 2002
    In the US RadioShack should have them. If you are in the UK I don't really know, as I don't live there, but I would say Maplins might just because they are often mentioned!
  5. Adam
    Adam What's a Dremel?
    26 Jan 2002
    Turning the AT power switch off then on again should have the same effect as the momentary switch if you can't be bothered buying one :lol:
  6. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Good old Maplins www.maplin.co.uk and do a search for momentary switch
  7. Hitman
    Hitman Minimodder
    18 Oct 2002
    Thanks, but I dont know a thing about 'proper' electronics, ie different types of switches, etc, I only know a little bit.
    I looked up momentary switch, but Im not sure which one to get.
    Also, when I get the switch, shall I just cut the power wires coming from the old 486 switch, and solder them onto the new one?
  8. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    For a momentary switch just get whatever looks good to you. They all more or less work the same way.
    As for when you get it, just as you said, chop off the wires to the old switch, keep the wires and solder on the new switch.
  9. Hitman
    Hitman Minimodder
    18 Oct 2002
    Just to check, the 'poles' are where I will solder the wires, so I need a double pole version?
  10. KevinOwns
    13 Jan 2002
    You only need a switch that has two things in the back for the two wires. And it doesn't matter which goes where, since all that the switch is doing is completing the circuit.
