Power Cable problem
Discussion in 'Hardware' started by BenJa, 9 Jan 2004.
  1. BenJa
    BenJa What's a Dremel?
    26 Jun 2003
    Just bought a 2500 Barton, NF7-S, and a couple of sticks of Kingston Hyperx. Slapped them into a computer, and discovered that the PSU ATX cables are too short. :wallbash:
    I've been able to find an extension to the ATXPWR1 at kustompcs.co.uk, but the 4 pin ATX12V extension I'm having trouble finding.
    So any advice as to where I could obtain this elusive - and very sneeky - extension would be much appreciated. :)
    - Benja
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    What psu do you have? It could be time to upgrade...!
    Is there no way u can route the cable?
  3. BenJa
    26 Jun 2003
    It's a 550w qtech I believe, no way to route since the ATX connections on the NF7-S are at the middle left of the board. Cables are just too damned short!
    - BenJa
  4. BenJa
    26 Jun 2003
    Oh and the fact I have a whooping great zalman 7000a-cu in the way doesn't help, but I don't think the cables would have been long enough even if I had picked a more reasonably sized HSF.
  5. robdos
    robdos What's a Dremel?
    19 May 2003
    Product code A46AK at Maplins.
    4 Pin 12v P 4 Extension Cable See Prices Below
    Bigger Picture
    · 4pin 12V ATX plug - 4pin ATX jack
    · Designed to extend the 4 pin 12V power supply between the mains adaptor and the motherboard.
    · Uses high quality components
    £2.99
    Do a search on 12v if you cant find it.
  6. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    that cpu and m/b combo is the overclockers chioce atm, if you are intending to clock, get a better quality psu. all of the enermax/antec/golbalwin psu's tend to have long cables, and a 420w from a decent brand will be far better that the qtec.
