PSU Power cable?
Discussion in 'Hardware' started by AoE, 13 Oct 2011.
  1. AoE
    AoE What's a Dremel?
    4 Oct 2011
    Do you get a power cable with a new psu, awaiting a cx500 v2, just i didnt see it in the contents description
  2. murraynt
    murraynt Modder
    6 Jun 2009
    You should do, yes :)
  3. AoE
    4 Oct 2011
    thanks man, new to the building lark but learning quick :)
  4. Exangels
    Exangels What's a Dremel?
    13 Oct 2011
    i got a power cable with the 500cxv2 i bough recently so u should get one
  5. AoE
    4 Oct 2011
    just took order of the psu and brilliant cable managment in the connectors, its not modular but looks well, plus i got a nice wee badge for my case :), dont know why theres a leaflet for a motherboard in there however lol, I hope it works with my amd mobo.
  6. AoE
    4 Oct 2011
    got a question: as the fan is positioned on top of the psu , rather than at the side next to the power cable insertion, how should the psu be positioned , with the fan upward hitting the roof of the case or downward onto the mobo?
  7. murraynt
    murraynt Modder
    6 Jun 2009
    Most people say up but I face it which ever way the cables have to travel the least distance.
  8. moody89
    moody89 Minimodder
    19 Feb 2011
    If the PSU is at the top of the case I tend to point the fan on the PSU downwards so that it acts as an extra exhaust fan and helps keep the case cool. Most newer cases have the PSU at the bottom where it makes wiring neater and also keeps the PSU cooler etc. but proper ATX spec still has it at the top acting as an exhaust. I think it goes back to way back when PSUs were the only exhaust fan in a case ;)
  9. AoE
    4 Oct 2011
    ok so its fine if I point downward onto the mobo, as my psu is at the top of case.
  10. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    Yeah buddy, when it's at the top of the case; you generally want it pointing down, as there's no gap at the top!
    TSB
  11. AoE
    4 Oct 2011
    cheers mate, I wonder if it will improve my windows cpu rating as its replacing a tsunami 400w haha.
