Displays Power Cord
Discussion in 'Tech Support' started by Comfyasabadger, 9 Aug 2013.
  1. Comfyasabadger
    Comfyasabadger New Member
    23 Jun 2009
    Hi Guys,
    I've just moved house and in the process I think I have binned the power cord for my SyncMaster SA300.
    Would anyone know if you can buy replacements? as the only ones I can find are listed on US sites and am not sure if they would be usable.
  2. Big_malc
    Big_malc Well-Known Member
    7 Sep 2010
    is it not a normal kettle lead power supply like this
    if so Kettle Lead 2m
  3. Big_malc
    7 Sep 2010
    My bad not a kettle lead
    samsung ac adapter should find what you wont in that lot have to match voltage and amps :D
  4. lancer778544
    lancer778544 Well-Known Member
    5 Jan 2011
    I found the PSU on Ebay which should be compatible and its 110-240v compatible so it'll work over here. You might need the power cable for it though which I think is the standard cloverleaf cable.
