Linux "Power Down" = I'm waiting...
Discussion in 'Software' started by sik wit it, 14 Jul 2004.
  1. sik wit it
    sik wit it What's a Dremel?
    1 Jul 2004
    Red Hat 9 issue
    for some wierd reason when I get to the end of my shutdown session screen, the words "Power Down" appear but the computer doesn't turn off
    the harddrives have been halted but the computer will not turn off automatically
    i recently installed it onto a new drive and this is the first problem and the first time I have experienced this with linux...I have installed the same OS onto many other systems before
    i have an updated bios and a good mobo (abit IC7) which is able to carry out the auto-turn off feature (i know this because it does it with windows)
    please help!
  2. lunix_user
    lunix_user What's a Dremel?
    31 May 2004
    ok, this isnt such a terrible problem.
    first of all, since rh9 is a dated distro, you might not see support for all of the advanced acpi stuff.
    in the bios, what is your power button set to.
    It is probably safe to just turn it off once that happens.
  3. sik wit it
    1 Jul 2004
    no i hit the power button and it turns off i just want it to do it automatically
