Modding power over ethernet
Discussion in 'Modding' started by best49erfan, 6 Dec 2004.
  1. best49erfan
    best49erfan What's a Dremel?
    27 Dec 2002
    I would like to do this:
    http://www.g4techtv.com/videos/index.html?video_key=8884
    but WITHOUT cutting my power cables, so I need to get the plugs, both male and female.
    I have a Westell Wirespeed modem and a Microsoft MN 740 router. Anyone know how to tell what plugs I would need and where to get them.
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    you shouldn't worry about cutting the cables - it's easy if you just get the right tool. you could save moeny too, and have the tool at the end of it all too!
    unless there's another reason you can't cut the wires?
  3. best49erfan
    27 Dec 2002
    warranty
  4. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Take the wall wart into Radio Shack or a similiar place and they should be able to hook you up. This is one of those things I wouldn't buy until after I've physically checked the fit of the plug.
  5. Caj Darkmoon
    Caj Darkmoon What's a Dremel?
    1 Aug 2004
    Hmm... that's a sweet idea.
  6. Drivel
    Drivel What's a Dremel?
    30 Oct 2004
    looks sweet :thumb: :thumb:
    what is a warranty :confused: :confused:
  7. Leevi
    Leevi What's a Dremel?
    28 Jul 2004
    this should do it :thumb:
  8. Drivel
    30 Oct 2004
    DUDE ive been looking for that pic LOL
    i love it can i buy the america ver. off of u i got some pcs that need that they are misbehaveing :naughty: :naughty:
  9. best49erfan
    27 Dec 2002
    I want to use plugs like the power adapters have and the actual devices have.
  10. TheMuffinMan
    TheMuffinMan Minimodder
    26 Apr 2004
  11. ajack
    ajack rox
    17 Apr 2003
    Are you sure you read the entire post, TheMuffinMan?
  12. best49erfan
    27 Dec 2002
    I normally record the screensavers, but i watched this one and did not record it. anyone know what episode it was?
  13. Mortus
    Mortus What's a Dremel?
    30 Sep 2004
    I think POE is good when placing a Access point out of reach of a power slot ..... or if you are setting up a access point outside
  14. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    The only reason i can see it not working is the voltage drop. Because the parts are cheap (unless you have to get them couriered to you), i would say just make it, with the rj45 plugs, and try it with a long network cable. But i am going to have to try it
    I just found the article for the poe, http://www.nycwireless.net/poe/ it looks the same as what was posted on that link earlier, but in article form.
  15. best49erfan
    27 Dec 2002
    That is what I am looking to do. I just need to find the connectors.
