Modding Power & reset buttons
Discussion in 'Modding' started by burnoutuk, 6 Aug 2003.
  1. burnoutuk
    burnoutuk What's a Dremel?
    18 Feb 2003
    I've been looking around for a new power and reset button but not seen anything good yet.. apart from the 'vandal Resistant' ones anyone suggest some good buttons (UK)
    Also where do you guys hook LEDS upto? say if i just wanted to put a few around the inside of my case.
    Thanks :rock:
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    vaaaandal resistant is the best button in the world!!! and generally i hook my LEDs up to a molex connector, with a resistor :D
  3. burnoutuk
    18 Feb 2003
    Is it just Maplin that sell them? and whats the cheapest place to get things like LEDS and resistors?
    Oooh and by the way Malcs nice case :dremel: :rock:
  4. malcs
    24 May 2003
    thanks :) ive got all my resistors, LEDs and my big vandal resistant button off maplins they were pretty good, cheap (except for the button but i dont know where else to get that) and all the other stuff is good though :)
  5. kong
    kong cnc-guy
    24 Feb 2002
    A looooong time ago, I was looking for soe nice buttons, and never wanted to pay the stupid prices for the anti-vandal ones, so I got an old stereo from the scrap yard and ripped off the nice silver push-button controls. They made lovely switches.
  6. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    I reccommend industrial-style. they look kool, and are built to last.
    (or at least they had better be, they're 9-10 bucks a peice)
    plus you can get 'em backlit, or you can get stuff like flip switch gaurds, which, unlike the toggle switch covers, you can get for less than 4$.
  7. WireFrame
    WireFrame <b>PermaBanned</b>
    24 Feb 2003
  8. Miku
    Miku What's a Dremel?
    11 Mar 2003
    Just make your own by following bard's guide:rock: The vandal resistant look better than any other
  9. burnoutuk
    18 Feb 2003
    Yeah i saw that, only problem is I dont have one of the lil cube bits where the power wires are conected to (Not a clue what there called :sigh: ) and dont know where to buy them...
  10. Pug
    Pug What's a Heatsink?
    16 May 2002
    I bought my non-illuminated ones from RSWWW.com - for the price of one illuminated, I got two non-lit (a raised one for power and a flush one for reset).
    Crap pic, sorry. I think the raised one is the top one.
    [Edit] :idea: Ooh! I just had a thought on how to mod an illuminated ring around them. :dremel:
  11. KrazyIvan
    KrazyIvan What's a Dremel?
    18 Oct 2002
    I just really like the illuminated vandel switches. I had to buy one even though they are expensive:
  12. malcs
    24 May 2003
    all agree then that definately vandal resistant :D
  13. KrazyIvan
    18 Oct 2002
    I hooked up the lighting on my vandel switch up to the power pin header of my motherboard. If you want to hook up several LED's you would probably need to tap one of the 12V or 5V lines from one of the molex conectors.
