PSU Power Supply Confusion...again...
Discussion in 'Hardware' started by TheManicGibbon, 27 Sep 2009.
  1. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    Hi
    I have a little confusion with my PSU...again.
    Right, so I want to upgrade my machine.
    I would like to add a new graphics card and a second hard drive. The trouble is, I don't know whether or not my PSU can handle it. For various reasons, I cannot upgrade my PSU My current spec is in my signature. None of my components are overclocked.
    I currently have the Dell version of the ATI HD3650 (256MB). I would like to swap it for a Sapphire version with a bit more grunt.
    Card
    The trouble with this is that, although I am running a 3650 at the moment quite happily, the ATI site suggests a minimum spec of a 400w PSU. I only have a 350w PSU. Here is the sticker on the side if that helps.
    I also want to add a Samsung SpinPoint F1 1TB. Will this fry my PSU?:wallbash:
    I did the Power Supply calculator, and it said i needed 228W as my system is.
    When i amended it include my upgrades, it said i would need 255W.
    How accurate is this site? Is it correct?
    Essentially, can I add a 1TB Samsung SpinPoint F1 and a Sapphire HD3650 512MB to my system with my existing PSU.
  2. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Um, what makes you think the Sapphire version of the same card will be any faster? It may have a different cooler or slightly higher clocks (posting a GPU-Z screenshot of your current card would verify), but it's still the same GPU at the end of the day, so definitely not worth a £35 upgrade.
    I'm interested; what are the reasons you can't upgrade the PSU?
  3. TheManicGibbon
    12 Aug 2009
    Upgrading because it doubles my graphics memory from 256MB to 512MB, and because the Sapphire card has 2xDVI, which I need.
    For some reason, the Dell one has 1xDVI, 1xHDMI and 1xDisplayPort.
    Reasons I can't upgrade my PSU:
    -Money
    -Time
    -Skill
    -Worried I'll muck it up (I manage to muck up most other stuff except fitting RAM and graphics cards:clap:)
    Will it work though?
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Right, first things first ditch that PSU and get a decent quality one instead of wasting your money on buying the same GPU with more memory.
  5. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    You do know that there are HDMI to DVI adapters?
  6. TheManicGibbon
    12 Aug 2009
    Yeah, the problem is that the an HDMI cable doesn't fit into the HDMI slot because of where the card is positioned. There is a metal lip on the case which stops the plastic bit of the cable from engaging.
  7. Sir Digby
    18 Jan 2009
    Ah, that's pretty terrible design.
    Would stripping off the cover from a HDMI cable work?
  8. GoodBytes
    20 Jan 2007
    I didn't see benchmarks, nor know the card, but by doubling the memory, it may get about 10-15% increase in performance as textures fits better. Is it worth it? of course not.
    Get a new computer case, transfer everything to it without braking anything. (of course before you do such a thing see if your motherboard is a standard format so that the screw holes fit the new case. Get a normal PSU with more power and get a better GPU.
  9. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Your current PSU will work fine if you really don't want to upgrade it. A decent PSU only really becomes a priority on higher end systems or if you're overclocking.
    The extra vRAM won't make much difference unless your monitor resolution is really high - the GPU will always slow down performance before it runs out of memory, so IMO is a pointless upgrade.
  10. TheManicGibbon
    12 Aug 2009
    I really do not want to upgrade my PSU. I only need a new graphics card for the ports, but the SpinPoint is pretty much essential.
    I have a spare VGA monitor, but the only free ports on my card are HDMI and DisplayPort. Will I be able to connect it somehow?
    The current PSU will work though?
  11. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Yes, the extra memory on the graphics card and an additional HDD will make little difference to the overall power draw.
  12. TheManicGibbon
    12 Aug 2009
    To try and save a bit of cash...
    Is there any way to connect a VGA display to an HDMI port?!
    Would:
    Filed down HDMI cable (see above)
    V
    HDMI-DVI Adaptor
    V
    DVI Cable
    V
    DVI-VGA Adaptor
    V
    Monitor
    work?
  13. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Perfectly valid, if money weren't an issue,
    atm I think you should just get the HDD, getting the same graphics card a second time as an improvement doesn't make much sense
    Probably, are you a fan of input lag though? That many adaptors and convertors and cables can't be good, atleast I think so
  14. TheManicGibbon
    12 Aug 2009
    :idea:
    Had a bit of a brainwave:
    IDEA!
    would this work?
    Don't know why it didnt occur to me before.:duh:
    EDIT:
    Use this instead of DVI-HDMI converter?
  15. GoodBytes
    20 Jan 2007
    Sorry it will not work. The adapter must be on the video card... as for example, the DVI plug on your GPU outputs VGA as well, but your cable most likely does not. I onced tried that, and despite having those DVI cables with all it's pins.. it failed the work. My guess, in my situation, is that despite having all the pins on the plug, the wires are not there OR the adapter does some wiring loop or something to tell the GPU to output a VGA signal.
  16. TheManicGibbon
    12 Aug 2009
    What about this? People seem to have got this to work.
    @GoodBytes: I drew the diagram wrong: The DVI-VGA adapter plugs int the card, not the monitor.
  17. GoodBytes
    20 Jan 2007
    Looks good to me, diagram and cable as well.
  18. Krikkit
    21 Jan 2003
    HDMI has no analogue output - you can cable it to VGA, but it won't do anything.
    If you have a TFT already then do HDMI->DVI and then DVI->VGA for the other monitor.
  19. GoodBytes
    20 Jan 2007
    I am lost Krikkit, isn't what he is doing now? :confused:
