Modding Power supply modding question
Discussion in 'Modding' started by Ricx, 10 Feb 2004.
  1. Ricx
    Ricx What's a Dremel?
    10 Sep 2003
    Hi all,
    With my new rheobus and Aero7+ coming tomorrow in an effort to make my box less god damn noisy, I've had an idea. By chopping the power suppies fan wires, and soldering extensions that run out the power supply with a molex on the end, I could control the speed on the power supply fan, using said rheobus.
    Is this safe/feasable ? I know you need air flow round the supply, but surely knocking it down to about 7V wouldn't hurt non?
    Cheers !
  2. coorz
    coorz Miffed
    25 Apr 2003
    Affirmative, you can do that. Normally the PSU fan is already temperature controlled. Running the stock fan at 7volts should be enough cooling.
    Alternative is to swap the stock PSU fan with a silent one.
  3. Ricx
    10 Sep 2003
    Cheers dude, I'm pretty sure mines not temp controlled.. sounds like an aircraft taking off 24/7.
    Thinking about it sticking an evercool in there couldn't hurt either... hmm.
