PSU Power supply n00b
Discussion in 'Hardware' started by mashupmark, 25 Jun 2009.
  1. mashupmark
    mashupmark Hacktastic!
    20 Jun 2009
    Chaps,
    Just got my new motherboard and I was wanting to drop it in to my old case.
    Only problem is the new mobo has a power connector on it I haven't seen before, and isn't a plug available on my power supply :(
    Motherboards I have used before are the large connector and then the plug that goes next to the processor like this: [​IMG]
    But my new motherboard has an 8 pin connector like this:
    http://www.overclockersonline.net/images/articles/biostar/n750a/large/n750a10.jpg
    Do I need a new power supply too? :( If so what make and brand should I be looking at?
  2. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Yep, a new PSU is due.
  3. mashupmark
    20 Jun 2009
    Damnit! I thought as much! :D
    What kind of PSU do I need?
  4. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Just don't be cheap about it, the PSU is the heart of your system. I prefer Corsair or Tagan personally.
  5. mashupmark
    20 Jun 2009
    I know, I won't skimp :) But what is this plug called? How can I know that my new psu will have this weird plug on it?
  6. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Most modern PSUs have at least one of them. You can usually check on the box or on the manufacturer's website.
  7. GoodBytes
    20 Jan 2007
    Look for PSU that are ATX12V v 2.2 or newer.
    Corsair PSU are all using the latest ATX version power connection system.
    The Antec Neo H1 and the Antec TruePower New
    I don't know the models of other brands... but basically if it's like 2007-2008 product release it should be the latest ATX.
    thehippoz likes this.
  8. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Advice it not correct strictly speaking, i would recomend a new PSU but you don't absolutly need one.
    It will be fine with 4pin cpu conection.
    Did the 8 pin socket next to cpu not come with a cap that can cover 4 of them?
    badders and thehippoz like this.
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    yeah if your running something like a dual core you can sometimes get away with plugging in just 4 pins out of the 8- check your manual (rep you and good =])
  10. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Although I seriously doubt that your current PSU is a quality unit, I can +1 that it should work with just the 4-pin one.
  11. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    What is your current PSU anyway? if it is a decent old one it may be OK, especially if you are running low powered components.
    The connectors are EPS 12v and a 24pin ATX connector.
    Bit-tech do have a lot of PSU reviews so have a look at them!
