PSU Power supply possibly needed.
Discussion in 'Hardware' started by pilsner72, 1 Jan 2018.
  1. pilsner72
    pilsner72 Active Member
    2 May 2011
    I think my Corsair CX 750 on its way out, I think it might not be supplying enough power. Today noticeable went to play Star wars Battlefront 2 and pc rebooted, checked event viewer, critical at 16:44 unexpected loss of power. It may have been glitchy mid last year.
    Corsair RM850X priced at £118 could possibly primenow one tonight. Is it recommended or overkill?
    AMD Ryzen 1600
    GTX970 strix
    Mostly Green HDD x 3 I think one is 7200RPM Black.
    1 x SSD
    Seems to be working fine at the moment
  2. lancer778544
    lancer778544 Well-Known Member
    5 Jan 2011
    850w is major overkill. I think 550-650w for a single card system like yours would be about right. That is, if it is the PSU that's at fault, otherwise you could be throwing money away.
    pilsner72 likes this.
  3. adidan
    25 Mar 2009
    You could check a PSU calculator - lots of manufacturers have them (be quiet, coolermaster definately have). I would link but i'm on my phone.
    But yeah it's overkill my 650w is overkill for my 3770/16gb/4xSSDs and 1080.
  4. pilsner72
    2 May 2011
    The graphics card and the PSU are the oldest components in the system 3-4 years old, I do want to go back to a modular PSU, my case isn't that wide and the older 4 way molex wires are tied up at the bottom of the case. So would like to clear that space up at the bottom of the case. The rest are in the back compartment power and sata cables.
  5. pilsner72
    2 May 2011
    I have noticed one a 650w in the marketplace and tempted.
  6. adidan
    25 Mar 2009
    A decent brand one will be fine for your system.
  7. CorsarioJoao
    CorsarioJoao aka JuanPirate
    10 Nov 2015
    I would suggest to take a look at Bitfenix Whisper M ,Seasonic Focus Plus or EVGA B3-G3 lines
  8. pilsner72
    2 May 2011
    Thanks, will be changing the Ryzen system to a more solider/efficient supply and go from there, A clean install was not done straight away until 3 months after changing from intel to AMD.
  9. pilsner72
    2 May 2011
    Looking at getting the EVGA G3:thumb:
  10. TheMadDutchDude
    23 Aug 2013
    Fantastic units. I highly recommend them. :)
  11. pilsner72
    2 May 2011
    Just ordered from Amazon £1.97 cheaper than Scan lol. I should get it Wednesday.
  12. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Worth noting for anyone looking at this thread in the future,
    There are two ways to buy a PSU, to meet your wattage or for maximum efficiency and lifespan.
    Meeting your wattage is obviously cheaper, check the coolermaster wattage calculator, and go 100w above your max load for head room and future proofing.
    I personally go for maximum efficiency and extending lifespan.
    A PSU ideally likes to sit on load at about 60% usage, this is where the gold,platinum ect ratings come from.
    So if your system is pulling 450 at load from the wall, a 800-850w PSU is best for lifespan and efficiency. Not necessarily overkill depending what you want but people that always buy 1000+ watts are almost always over kill and not actually running there PSU efficiency, as under loading can be as bad as overloading in efficiency (not stress)
    pilsner72 and adidan like this.
  13. adidan
    25 Mar 2009
    For a titanium rating psus have to hit 90%+ efficiency on 20%, 50% and 100% loads. Actually, looking at it the Titaniums (must resist urge to abbreviate! :)) they need to hit that om 10% loads too - didn't know that.
    Any 80plus rated psu tends to differ by about 3% or 4% on the different loads with a minimum of 80% efficiency across 20/50/100. They're pretty good nowadays.
    Whatever the case investing well in a psu is the best policy. My Be Quiet cost a bit at the time but 8 years on and it's still going strong. Probably helps that the components it powers have got more efficient over the years.
  14. pilsner72
    2 May 2011
    Total power usage 344W at stock, including fans, HDD and peripherals
  15. pilsner72
    2 May 2011
    Installed and good, the unnecessary wire mass at the bottom of case is no more. I wasn't bothered about them on a bigger case, they could be hidden easier. I just needed to move the optical drive down a bay.
    adidan likes this.
  16. adidan
    25 Mar 2009
    Nothing like a good tidy :)
  17. pilsner72
    2 May 2011
    No unexpected restarts yet.
  18. adidan
    25 Mar 2009
    Awesome. Hope it continues.
