Power supply to just video card
Discussion in 'Tech Support' started by Mathmarauder, 27 Apr 2007.
  1. Mathmarauder
    Mathmarauder What's a Dremel?
    14 Jan 2007
    My power supply cannot reach my video card even with the molex to pci adapter. I have another psu sitting around and at this point it would just be easier if I can use the extra psu to power the video card. Is there any problem with doing this? There wouldn't be any other components plugged in.
  2. THEkorean
    THEkorean 42
    10 Jun 2005
    just extend the wires, shouldn't be too hard (cut, solder, tape, done) , an extra power supply will only clutter your case, and you would have to do some mods to it anyways to it will boot up with the rest of your hardware.
  3. Mathmarauder
    14 Jan 2007
    Don't own a soldering iron, nor do I have any experience with one. I'm college so more clutter doesn't really make much of a difference.
  4. krimson
    krimson What's a Dremel?
    16 Nov 2006
    you can buy extensions for your PSU that will save you a lot of hassle.. Two PSUs can really be a pita. its one thing to use a separate one for lights and water cooling and stuff, but when its components, you really want the mobo to be able to have control over your PSU.
    i would see if you cant get ahold of your local computer store, or even make friends with your campus computer group and see if you cant just get a cable... trust me, its a lot easier.
    http://www.cyberguys.com/templates/searchdetail.asp?productID=326
    they are like <$2 and are 12" long.
  5. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    If you wanna use a psu just for the gfx card you need to short out the black wires on the 20 pin molex and the two black wires on the 4 pin motherboard molex
