Apple Powerbook and a new PDA
Discussion in 'Software' started by Soulfly22583, 14 Feb 2006.
  1. Soulfly22583
    Soulfly22583 What's a Dremel?
    12 Jan 2004
    I have a powerbook g4 and need to get a new PDA in the coming months... would a PDA even be able to sync with my calender/address book inside of OSX?
    Any thoughts/suggestions/constructive criticism is GREATLY appreciated =)
  2. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    Missing Sync ftvv. I use it to sync OS X with my Pocket PC
  3. Soulfly22583
    12 Jan 2004
    Can you expand on this bud? Thanks
  4. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    Not got much time but this should give you all the nifo you need ;)
    http://www.markspace.com/
  5. SensesFail
    SensesFail Guest
    I think iSync works with the Palm Tungsten. To use a pocketpc or some of palms more powerful PDA's you have to buy (download?) a separate program...but it is entirely possible.
  6. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    I use iSync to sinc iCal/adresbook with a k750i and a Palm Tungsten. All basic stuff works great. But my phone didn't recognise some of the data in a entry in the adressbook.
    But with the palm it works pretty well!
    L
  7. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    As Lovah said, it all works with a Palm PDA, no extra software required. You either set it to Sync with the Palm calendar that it installs, or use the iSync conduit (takes a little bit of playing but it's all in the iSync help). I bought a Palm because I had heard Windows-based PDA's don't work on Macs. But as has already been said, you can download some software I think likeTHIS never used it though. I like my Palm PDA, the Windows ones I've seen are about twice the size.
  8. customh
    customh conflagration.
    22 Oct 2005
    as tom said
