Apple PowerBook Battery Recall
Discussion in 'Software' started by GreatOldOne, 23 May 2005.
  1. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    I know a few of you have just purchased PowerBooks, so this will be of interest:
    https://depot.info.apple.com/batteryexchange/index.html?lang=en
    Check your batteries! If you find you have one that's affected by the recall, get in touch with Apple via the form on the link above.
    This has been a Public Service announcement, In association with GOO and the Toast Marketing Board. That is all...
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    Assuming this is a different recall then before?
  3. GreatOldOne
    29 Jan 2002
    Yes, this is another, different recall. This is for PB's manufactured from Oct. last year through to May this year.
  4. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Checked mine over the weekend just in case but its fine :)
  5. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Hmm mine appears to be in the range.... but it's not showing any signs of over heating... all batts get hot while charging anyway...
    Is it really worth me sending it in?
  6. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Is it worth the risk? 6 have blown up sure the odds are in your favour. You'll get a new battery too which is a bonus :D
  7. Firehed
    15 Feb 2004
    If you don't mind the risk of battery acid all over your burned-from-overheating leg, then it's certainly not worth your time sending it in.
  8. Lorquis
    8 Sep 2002
    Tad overboard Firehed.... what I mean is... if only 6 out of god knows how many devices have been sold... have gone burny.... then there's little chance mine would be the 7th...
    after all it's a voulentary recall... plus.. they're recalling all of the batts made by the same company probably just to be sure...
    plus... there's isn't any acid in these batteries you fish.
  9. Firehed
    15 Feb 2004
    meh whatever, just making a point that there's no sense taking a risk. And you get a fresh battery out of the deal so you may up your battery life a bit.
  10. RTT
    RTT #parp
    12 Mar 2001
    1) most definitely
    2) new, fresh battery for nothing!
  11. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Hi !
    I've got a 12" powerbook, bought in ... I dunno .. March/April.
    The model number is A1079. So that checks out.
    But I'm confused with the serial numbers.
    The site says
    12-inch PowerBook G4 A1079 3X446 – 3X510
    Mine says
    *3K50438GRJMB
    So its within 446-510
    But its K instead of X.
    Do they mean X = "whatever"
    or X = Letter X
    Because the picture telling where to look , gives an example with 3X446. So it would seem x = letter x.
    Thank you!
    Worried L.
  12. GreatOldOne
    29 Jan 2002
    As far as I'm aware X = letter X, not any character. So you're fine.
  13. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    Thats what I assumed mines a 3k model :)
  14. Lovah
    10 Jul 2002
    Ok, great! thanks
    L
  15. Haddy
    22 Jan 2002
    Personally I would give them a call just to double check, especially after seeing what RTT posted (click me and be afraid)
