Powerbook disassembly
Discussion in 'Article Discussion' started by WilHarris, 21 Oct 2005.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
  2. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    Wow, so it's actually possible to take one of those things apart? Crazy stuff!! It's such an anticlimax to see that there's simply "normal" hardware inside there. I was expecting magical glass tubes filled with blue plasma and lots of shiny round bits everywhere.
  3. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    It's so sad to think that this actually could qualify as modding for all the work you had to do...to replace a part that should be openly serviceable. Go apple. :p
    That said, good job! Glad it works, and hope you don't keep it on your lap too much...
  4. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    This x-ray's pretty cool:
    Shows you how basic the battery really is.
  5. RTT
    RTT #parp
    12 Mar 2001
    You actually wouldn't believe just how abused that laptop is. The pictures do it no justice :D
  6. Andy Mc
    Andy Mc Modder
    23 May 2002
    FYI: the wall paper in the last shot is another from little-gamers.com :D
  7. Godboy_g
    Godboy_g What's a Dremel?
    13 Aug 2004
    Since you already had the case apart, you should have painted it..... It would look sweet with the Bit-tech logo on there. :thumb:
  8. xheadinthecloudsx
    xheadinthecloudsx What's a Dremel?
    21 Oct 2005
    Disassembly/repair guides for most powerbook/ibook models can be found on: http://www.pbfixit.com/Guide ... and they show you how to open it up without damaging the front of your optical drive.
  9. r00t69
    r00t69 What's a Dremel?
    2 Apr 2005
    :D
  10. Deep-Blue
    Deep-Blue Part-time Overclocker
    1 Feb 2004
    I feel your pain dude. My Powerbook 12" is starting to get a bit sluggish and occasionally doesn't boot either. Having said this, i think i still have the extended warrenty on this, so i may just have to give em a call.
    Oh BTW, kudos on the great choice of wallpaper. Its funny how LG wallpaper and Macs just go hand in hand!
  11. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    is that just 8 AA batts?
  12. ElThomsono
    18 Mar 2005
    I don't think so, they're too big (using the HDD as a scale). Just that they've soldered together a load of cylinders and stuck them in a square box, not very space efficient :confused:
  13. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    That poor powerbook. Don't know how you can give so much abuse to something that expensive :(
  14. Arkuden
    Arkuden mow?
    9 Jul 2004
    no you can see the standard battery plugin the top right of the rectangular area that those tubes or cells cover. 8 cell battery i would imagine. At least ive heard of them being referred to as such becuase you can get an optional 12 cell battery with laptops as an option these days.
  15. phantomxc
    phantomxc What's a Dremel?
    7 Dec 2004
    If you think it was hard to get that thing open, try taking out a logic board and putting a new one in.
  16. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
    That's what all battery packs are - powertools, laptops, cameras, etc. That's why it's such a swizz when they charge you loads for them - and you know what it's not even the cells that go it's the controller boards on the packs. :duh:
  17. DreamTheEndless
    DreamTheEndless Gravity hates Bacon
    27 Jan 2004
    ...As I've been saying for years. SDRam, now DDR and DDR2 (ecc or not); scsi, IDE, sata; usb; pci; agp; pci-x; pci express....
    My (now gone - donated to a good cause) beige 300mhz g3 powermac took SDram and had a pci video card. I know a long time ago they used different hardware than most of the x86 world, but times have changed.
    And yet - you still have people who say you shouldn't buy a mac because you can't upgrade them or can't find parts for them......
    I bought new ram for my sisters clamshell (toilet seat cover) iBook in the electronics section of the grocery store!!
    Yes - it's the same hardware.
    Sorry - just realized this was a rant and didn't mean it to be. It's just that this is a conversation that I have had too many times over the last several years. I have counted to 10. I am calm now. I swear.
    (It's the same hardware.)
  18. ElThomsono
    18 Mar 2005
    Yeah, but at least on my laptop they've accepted it, the battery pack looks like 2 long cylinders side by side, a sort of 8 shaped prism.
    But yeah, batteries are a huge rip off :rolleyes:
  19. joshua
    joshua What's a Dremel?
    21 Oct 2005
    Good to see you picked a non-Toshiba drive, crappy crappy drives. Not a lot of joy explaining to a user the benefits of loosing 5-7 years of email/files and to look at the positive benefits of the situation. To see the situation as a kind of data enema cleansing the bowels of their laptops.
    I've had to do this today due to the failure of the same exact model drive you had, and replaced 20 over the last year. luckly toshiba's and hp's only have 2 screws holding drives in, makes replacing far easier.
  20. BurntKona
    BurntKona What's a Dremel?
    19 Oct 2005
    Nice work disassembling. Got to do the same myself with an Acer Aspire 1500. I guess it isn't only Apple that doesn't believe in making things easy for the techy user to repair.
    And it was a Toshiba drive that went Kaputt. 17 months old. At least it hinted at impending doom and back-ups were up to date.
Tags: Add Tags
