Hardware PowerColor Radeon X1950 Pro SCS3
Discussion in 'Article Discussion' started by Tim S, 11 Apr 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Veles
    Veles DUR HUR
    18 Nov 2005
    You certainly gave that card a grilling :eek:
    I think thats probably enough grill jokes for one day :p
  3. Nature
    Nature Minimodder
    21 Nov 2005
    Good card, though 512 megs seems a bit standard for any 950 pro in production these days. Considering the pcb is identical for both the 256 and 512....
    I've really wanted a 8xxx series card since they've come, but I'm waiting for the evil Nvidia to morph to 80 nano meter like AMD has done here. That BFG water block card on the right side of my screen would be alot more tempting if it were 80-or dare I say 65 nm! And of course GDDR4! The industry is entirely to comfortable on ddr3..
  4. kenco_uk
    28 Nov 2003
    Page 1 - last para - "and trail versions" - 'trial'
    Page 2 - para 4 - "Although it’s a 512-bit internal memory interface, it’s still a 256-bit connection to the 256MB of local GDDR3 memory, though." - last 'though' not needed
    Page 2 - para 8 -"That’s not all though, as there is more cooling on the card than the heatsink we’ve been taking the piss out of for the last couple of pages though." - not sure I agree with cursive words on a professional site, but BT:NG and all that.. also, last 'though' not needed.
    Page 2 - para 10 - "Moving onto the selection of ports on the card’s PCI bracket, there’s a pair of HDCP compliant dual-link DVI ports capable of running a pair of monitors at resolutions up to 2560x1600 each." - use of 'pair' in one sentence, perhaps 'duo'?
    Page 2 - last para - "This is like what most other board partners.." - omit 'like' to make the sentence sound less chavvish
    Page 3 - bullet points - no need for semi-colon use after each bullet point
    Page 6 - para 1 - "There are also real time shadows and a subtle HDR lighting effect too." - either 'There's..', omitting 'are' OR omit 'a' and add an s to 'effect'.
    Page 7 - para 2 - "around your ankles with no where to go." - nowhere, one word
    Good review. The difference between a 7900GTX and 8800GTS is quite staggering.
  5. Tim S
    Tim S OG
    8 Nov 2001
    :blush: thanks for the repetitions/typos!
  6. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    I don't know if it was mentioned but I don't think you can do crossfire with the cooler in the way.
  7. Tim S
    Tim S OG
    8 Nov 2001
    It's hinted at the bottom of P1 and then discussed in full on P2. You're right though, CrossFire isn't happening on this card. :thumb:
  8. pendragon
    pendragon I pickle they
    14 May 2004
    wow that's one humungous grill on that card O_O
  9. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Well you COULD do CF with internal connectors, you'd just need long ribbons or to have PowerColor remove a few fins so the bridges would fit
  10. Fozzy
    25 Jan 2005
    Yea but I've never seen a long ribbon like your describing and I'm not sure how many people are willing to cut up their videocard and void the warranty.
  11. Tulatin
    16 Oct 2003
    Well something like what ASUS gives you for their 680i motherboards.
    And there's no cutting of the videocard involved, just some snipping of sink fins
  12. Tim S
    Tim S OG
    8 Nov 2001
    If anyone was going to do anything like that, I'd guess it'd be one of the many modders on this forum. There's bound to be someone crazy enough!:D
  13. DougEdey
    5 Jul 2005
    I'll do it, if you provide a card :D
  14. Fozzy
    25 Jan 2005
    Oh I'd do it too. But I'd sooner watercool it and keep the stock HS for RMA's
Tags: Add Tags
