Modding Powering a hub
Discussion in 'Modding' started by SJH, 6 Feb 2004.
  1. SJH
    SJH Minimodder
    24 Dec 2003
    On my next project I plan to integrate my little 5-port Netgear hub into my case.
    However I don't want to have to have the power adapter in there as well, as it means it will take up one extra socket and this thing is going to be designed to be portable.
    On the adapter it says "Output DC 7.5V 800mA".
    Can I use my PSU to power this, perhaps with a resistor or two?
    -Sam
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    I'll be brief, since techincally I'm not supposed to be viewing the forums right now :)
    Resistor: no. Regulator: yes. Most likely input has +5v regulator, so you can bypass and power off of +5vSB line (SB because people might prefer to stay connected if your computer is off).
