Electronics powering molex device from USB power supply
Discussion in 'Modding' started by simosaurus, 13 Jan 2007.
  1. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    hi, i came up with the idea of mounting a blue neon under my monitor to backlight the stand and the stuff i keep underneath, and since its got several USB ports i wondered if it was possible to wire the inverter's power to the output of the USB. Im not even sure if USB provides enough power but i thought id ask if its possible :)
    if it helps the inverter is only using 2 of the wires from the molex - the yellow and the black next to it.
  2. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    i believe cathodes run off 12v and usb can power 5v
  3. Springs
    Springs Boing boing
    29 Aug 2004
    i believe it wont work.. the neon runs on 12V which is the yellow wire and USB can only output 5V
    best way to do it is run a molex from the case to where you want to...
  4. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    if you really want to get technical you could do it, you would need a dc-dc converter, there are many different versions but i wouldnt reccomend it. it would be best to just run a molex out of your computer
  5. simosaurus
    12 Jun 2005
    ah that answered my question guys, cheers
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Still technical, the current a CCFL uses is way over what USB is designed to deliver. A Bit tip is to fit some power sockets to a backplate to run external stuff. Add an inline 5A fuse to protect the PSU.
  7. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    ahh fair enough, i didnt realise that ccfl's drew so much current.
  8. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    While not meaning to pimp the sight but my mate runs http://www.neon-lights.co.uk he has on there mains powered inverters for neons and CCFL
    Cheers
    Kimbie
  9. agent420
    agent420 What's a Dremel?
    18 Apr 2006
    Or an appropriate 12V wall wart... 101 uses :)
  10. MixWizard
    MixWizard What's a Dremel?
    16 Jan 2007
    i prefer the backplate idea never thought of that.
  11. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    they dont, but once you step the 5v up to 12, more then doubling the current draw, and dont forget inneffiency of the DC-DC converter, you're pulling well over the 2.5w maximum power of USB.
    2.5w @ 12v is only 208 mA, not much current at all.
  12. MixWizard
    16 Jan 2007
    if not and this may seem a bit over board mod wise. but does your pc monitor require a transformer or does it have an IEC that goes straight into the monitor. quite a few monitors run off 12v so you could mod the entire monitor if you felt you were able to
  13. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    i tested mine just before i posted and mine was drawing 450mA which is a fair bit. and at 5v would be over an amp which is too much for a USB port
  14. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    So why not slap it to two usb ports to load balance?
  15. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    usually the load rating is for all of the one cluster together, but their might be more than one rail supplying the ports individually but you would still need 3 to cover the total loading. which i would not reccomend. i would just run cables from a molex or something. you could get a blank cover at the back and just put a socket in there and a plug on the end of the inverter, and then just power it from the inside of your computer, it would be alot neater. you could use 3.5mm audio connectors but someone will plug your speakers into it and blow them up, go to dicksmiths or tandy or radioshack and find a suitable connector for the job. clean and simple
