Networks PPPOA/PPPOE Passthrough
Discussion in 'Tech Support' started by Pookie, 31 Jul 2017.
  1. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    Sorry if this is a dumb question, what modem do you guys suggest I use for setting up a dedicated firewall? I have set up loads of firewalls on fibre and EFM connections but not an regular ADSL lines.
    The firewall can only passover with PPPOE, so I need a modem that can bridge the 2 together. I did try with a Zyxel VMG8925 in bridge mode but it didn't work. The customer cant upgrade to fibre or afford EFM. Thanks for looking :thumb:
  2. Chairboy
    Chairboy I want something good to die for...
    10 Jun 2004
  3. Pookie
    4 May 2010
    Thanks for taking a look, I think I'll buy one of those 130's to have a play with :thumb:
    Chairboy likes this.
  4. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Any Ethernet DSL modem should work. They tend to do the PPPoA/PPPoE themselves and then just bridge to the connected device.
  5. Pookie
    4 May 2010
    I have only had 2 Zyxel routers to play with and neither worked in bridge mode. The Vigor 130 arrived today, I'll find out friday when I'm onsite if it works or not :lol:
  6. jinq-sea
    15 Oct 2012
    Draytek 130 should do just what you want. I use one with my Unifi Security Gateway, as far as I understand it, it passes through the PPPoE.
  7. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Just get a modem and configure on the firewall, if it has PPPOE settings then you just need something to dial, a 120 will work, a 130 will work AND will work with Infinifty/VDSL. if you know anyone with an old infinity box that will also probably work or if you have one, I've used them in a bind but since BT dont supply them anymore, they are few and far between! but might be cheaper buying one of those than a draytek.
    EDIT: just read you have bought the 130 already. good choice as they are good!
