Case Mod - Complete -Praetor- project
Discussion in 'Project Logs' started by AKMod, 12 Apr 2018.
  1. AKMod
    AKMod New Member
    29 Mar 2018
    Hello,
    I’m AK MODs from Taiwan. This is my first time send a message, I am excited to show my work and hopefully learn a lot along the way.
    My project is called Praetor. I will enter with the C700P. The 4 bar handles will be polishing finished and the chassis will have a rough black finish. I will add a bit of aluminum accent inside. It will have glass on both sides with mirror finish. I will try to keep it simple with a clean liquid cooling setup.
    Hardware:
    Asus Maximus X Formula
    Cooler Master V750
    Cooler Master MasterFan Pro 120
    Nvidia Geforce GTX 1080 Founders Edition
    Zadak Shield 8GX4 DDR4
    Zadak Shield 240 SSD
    Cablemod Custom Cable
    Water cooling:
    Bitspower Nvidia GTX 1080 Special Edition
    Bitspower Fitting Bitspower Radiator 360
    Bitspower Brass Hard Tubing
    Cooler Master MasterLiquid Maker 240
    Custom Water-Blocks
    Custom Nickle plated copper tubes
    Custom Spray paint
    Custom Internal structure
    Custom lighting
    Custom Cable
    I want to thanks so much to all of my sponsors which I have a pleasure to work with!
  2. AKMod
    AKMod New Member
    29 Mar 2018
    Cooler Master COSMOS C700P
    Cooler Master V750
    Bitspower Fitting
  3. AKMod
    AKMod New Member
    29 Mar 2018
    Project Praetor Update #1
    The use of 12 mm copper tube and electroplating processing.
    Dismantle the shell with modified and parts parts to measure.
    Laser cutting acrylic.
    Dozen sample.
  4. AKMod
    AKMod New Member
    29 Mar 2018
    Start to sanding after the cutting processing completed.
    Sanding with waterproof abrasive paper is the pre-preparation of spray painting.
    The better the texture of product is, the harder the processing has been haha...
    Spray paint the electroplated silver as primer after finish the sanding.
    Cover the primer before spray painting paint, then the Last three colors use spray painting.
    Make the Light guide plate for memories.
  5. AKMod
    AKMod New Member
    29 Mar 2018
    3D rendering of internal structure.
    Hidden cable box.
    Processed aluminum parts.
    Aluminum, Anodizing matte black.
    Cable comb 10mm CNC.
    Acrylic matte black and white.
    10mm.
  6. AKMod
    AKMod New Member
    29 Mar 2018
    Prepare in advance.
  7. AKMod
    AKMod New Member
    29 Mar 2018
    3D schematic waterway board.
  8. AKMod
    AKMod New Member
    29 Mar 2018
    Copper tube processing and nickel plating, polishing.
    Inside paint, two-color design.
  9. AKMod
    AKMod New Member
    29 Mar 2018
    Front cover making CNC logo.
    Making a fixed mold.
    Making logo lighting effects.
    Custom cable.
    Light effect test.
  10. AKMod
    AKMod New Member
    29 Mar 2018
    Laser engraving backplane logo.
    Combination acrylic and lighting effect.
  11. AKMod
    AKMod New Member
    29 Mar 2018
    Water channel board test.
    Mirror sticker on the back, Reflective effect.
  12. AKMod
    AKMod New Member
    29 Mar 2018
    Upper cover ventilation panel modification.
  13. AKMod
    AKMod New Member
    29 Mar 2018
    Assembly.
    Lighting test.
    Tiring work.
    _Prometheus_ likes this.
  14. Mojo
    Mojo Well-Known Member
    18 Nov 2011
    Nice progress so far!!
  15. AKMod
    AKMod New Member
    29 Mar 2018
    Hello everyone !!
    The Praetor was designed to match the ancient uniform worn by the Roman commanders, known as Praetor.
    I've used darker color tones with chrome plated tubing to recreate their elegant uniform style.
    Most of the parts were custom made using CNC.
    Enjoy.
    Specs:
    Intel i7-8700K
    Asus Rog Maximus X Formula
    Nvidia Geforce GTX 1080 FE
    Cooler Master V750
    Cooler Master Cosmos C700P
    Watercooling:
    Cooler Master Masterliquid Maker 240
    Bitspower Nvidia GTX 1080 Ti Founder Edition Acrylic (Custom)
    Bitspower Leviathan Slim 360 4xG1/4" Radiator
    Bitspower Fittings(Carbon Black)
    Custom Water-Blocks
    Custom Spray paint
    Custom lighting
    Custom Cable
    Thank you everyone who supports this project!
  16. AKMod
    AKMod New Member
    29 Mar 2018
    Some photos..
  17. AKMod
    AKMod New Member
    29 Mar 2018
    I have been working for 90 days, haha.....
  18. AKMod
    AKMod New Member
    29 Mar 2018
  19. AKMod
    AKMod New Member
    29 Mar 2018
  20. Dopaaa
    Dopaaa New Member
    29 Jan 2018
    Awesome work. I love it! I really do.. Keep it up!
