Other Pre-built NAS Recommendations
Discussion in 'Hardware' started by JHarley1, 10 Dec 2010.
  1. JHarley1
    JHarley1 New Member
    17 Jul 2010
    Good Morning,
    I am looking for a pre-built NAS. Here is my ideal specification:
    • 2 Bay NAS
    • Decent Make
    • Capable of streaming movies to PS3 or 360
    • Store capacity of around 4 TB - over the 2 bays
    • Budget - £150.
    Could anyone recommend a good pre-built NAS? I have read the Bit Tech reviews - I very foolishly threw out my Custom PC edition with the NAS review's. I don't need anything fancy like the ability to torrent... There are a few on eBuyer that I found - but they all seem to have limitations.
    Many Thanks,
    J
  2. =DJ=
    =DJ= Torturing x86 since '86
    18 May 2010
    Hey there!
    There have been a few NAS threads over the last few days and you might want to take a quick look at these two:
    Home Server Project Help
    NAS Recommendations Wanted
    In essence, you should check out Synology and QNAP servers.
    I have a 2 bay Synology which I have been thrilled with (much better than the Buffalo Linkstations I've used before) and comes in at your budget (though without disks).
    It'll do everything you want and more!
    I know the CPC review you are referring to - the Synology DS210j came out top for price/performance at the time (which is why I bought one! :D)
    HTH,
    Dan
  3. JHarley1
    JHarley1 New Member
    17 Jul 2010
    Hey,
    Thanks for your advice. I have read the various reviews and I am going for:
    Synology DS211j NAS
    Many Thanks,
    J
