Modding Prevent scratches on panels
Discussion in 'Modding' started by cool_dude, 14 Aug 2010.
  1. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    hey guys
    just wanted to ask, when modding say cutting a window how do you guys prevent scratches where you turn the panel so its easier for you to cut when on a bench?
    I find that even with masking tape there are subtle scratches, any reccomendations?
    I guess paper and masking tape would be sufficient?
    Might be a state the ovbious question, but if you guys got some common sense asnwer that I seem to let go completley over my head then by all means let me know :D.
  2. talladega
    talladega I'm Squidward
    18 Aug 2007
    tape the whole thing. not just the spot you are cutting.
    or be more careful and clean off the junk.
  3. capnPedro
    11 Apr 2007
    Don't wipe the panel - you'll just scrape tiny pieces of swarf around the panel, scratching up the panel like sandpaper would.
    I use compressed air to clear away the filings, but a vacuum also works.
  4. bulldogjeff
    2 Mar 2010
    Yep agreed with all of the above. What I tend to do also with masking tape is to use a cloth to press down and rub the tape so it sticks properly and takes all the bubbles out.
