Windows Printing a secured powerpoint
Discussion in 'Software' started by Lovah, 4 Jan 2006.
  1. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Hi,
    Our teacher gave us the powerpoints that he used in class. When opening them in powerpoint it asks for his password. Then I click "Read-only" and I can view them fine. But I want to print these out (handouts), 6 slides a page. Because it is easier to read.
    But when I go to the print menu and click ok. It doesn't do anything.
    In powerpoint viewer, I can print them out fine, but only 1 per page. But I don't want that as I will end up with a huge pile of paper.
    Any help on how I could print these out 6 per page? Or how to hack the file?
    Thanks
    L
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Click on the left panel and press Ctrl + A then copy.
    Open a new PP document and paste, you should be able to use PP normally. :)
  3. Lovah
    10 Jul 2002
    I'll try that, thanks, hadn't though of that!
  4. Lovah
    10 Jul 2002
    Dosn't work mate. I can select them, copy them. But I can't paste them .. it doesn't even show up on the clipboard.
  5. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    Can you save the file in a different format (HTML, anything)? That might remove the password protection, but it might also mess with the formatting. Can you ask your teacher for his password and tell him that his PP is not precious enough to password protect if he's then just going to give the file out to everybody?
  6. Lovah
    10 Jul 2002
    I can't "save as". I can't print to pdf either. Don't think he is going to give out the password. :s
    L
  7. Arthur2Sheds
    19 May 2003
    That sucks. I hope you're not fond of trees, then. Good luck!
  8. dom_
    dom_ --->
    4 Jan 2004
    print screen each slide while viewing it :D
    will take ages but will work
  9. Lovah
    10 Jul 2002
    Well yeah, it will take ages. Its a view hundres slides. Got better things to do :) But thanks for the help though.
  10. funkymunky
    funkymunky Guest
    Try this...
    That might give you a fighting chance.. i know its a demo but i know you can purchase it. OR even find a work around.
  11. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Have you tried to open the file with OpenOffice?
  12. Lovah
    10 Jul 2002
    A friend of mine was able to make pdf-files with handouts! Got those to print out, it is printing atm.. Few hundred pages.
    Thanks for the help anyway!
    Haven't tried openoffice, was a good idea. But no need to anymore!
    L
