Displays "Pro" 24-27" IPS sRGB Monitor, Only Cheap
Discussion in 'Hardware' started by Gareth Halfacree, 15 Aug 2019.
  1. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    Before I start the thread in earnest, permit me a digression. Many moons ago, my mother bought a new bin for the kitchen. It didn't match the cooker it was next to, so she bought a new cooker. Which didn't match the fridge, so we needed a new fridge. Eventually the entire kitchen had been overhauled in a tasteful shade of avocado (hey, it was a different era) - all because of that £5 bin.
    Why do I tell you that? Well, recently I bought a £9 colorimeter to have a play with display calibration. Now I've bought a £109 colorimeter; and here I am, opening a thread about new and better monitors...
    Anyway: my current monitor is a Philips 'Brilliance' 240S1B1 TFT: 1920x1200, probably-six-bit-I-dunno, DVI-D and D-SUB inputs. Eight years old, £241 at the time, never been fantastic, hasn't improved with age.
    For an upgrade, I have the following want-list:
    • 24-27", preferably no larger.
    • Reasonably cheap.
    • IPS.
    • 1440p.
    • Pretty cheap.
    • 99-percent of sRGB (Adobe RGB can go hang.)
    • DisplayPort and HDMI inputs.
    • 60Hz or better at full resolution over DisplayPort.
    • Did I mention cheap?
    • VESA mountable, so I can use it on my monitor arm.
    • Matte anti-glare finish.
    • Cheap.
    When I say "cheap," I'm thinking around what I paid for the Philips only eight years better. I've only had a quick browse around, but I've found the following possibles on Amazon:
    Iiyama XUB2792QSU-W1 ProLite, £280 - six pounds cheaper than the same thing in black. I remember Iiyama being a decent brand for them as can't afford an Eizo, back in the days of CRTs. 75Hz refresh with FreeSync support at 70Hz (no idea if FreeSync-via-Nvidia actually works on Linux - I know there's a readout in the settings that tells me that my current monitor doesn't do Gsync.) Downsides: Iiyama's being a bit cheeky by claiming it's a "10-bit" panel when it's actually eight-bit plus-cheating, but it reckons it hits 115% of the sRGB gamut anyway.
    BenQ PD2700Q 27 Inch 1440p QHD Monitor for Graphic Design, £285. How can that not be great? It says "for graphic design" right there in the product name! Only 60Hz refresh, but 4ms response time to the 5ms of the Iiyama, with a claimed 100% coverage of sRGB/Rec. 709. It also claims to be a 10-bit panel, but I have my suspicions it's cheating like the Iiyama.
    Asus PB278QR 27 inc Professional Monitor, £307. Even better than the BenQ "Graphic Designer," I can be a "Professional!" It's not entirely clear what you get for the extra £20 over the competition, though...
    Workload, for any of 'em, is photo editing (though I'm using an entry-level DSLR, here, so let's not go overboard), general office use, bit of gaming.
    Thoughts?
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Arboreal and edzieba like this.
  3. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    A Dell Ultrasharp may be a boring choice, but it's rarely the wrong choice.
    bawjaws and Fingers66 like this.
  4. RedFlames
    23 Apr 2009
    If in doubt - Dell.
    BenQ iirc are usually solid choices in the pro/semi-pro sphere too.
  5. Gareth Halfacree
    4 Dec 2007
    Fair bit more than I wanted to spend - and it seems to be £426 on Dell Home and £355 *ex VAT* on Dell Business, which is... huh, also £426. Not sure I've ever seen the home and business pricing match like that before!
    Mixed reviews on Amazon, too, and that review you linked claims the overdrive mode that actually gives you 5ms GtG transition time is unusable in practice - which pushes it up to 8ms.
    Just not sure there's enough to differentiate it from the rivals at £90 less.
    Yeah, but my pair are crap anyway so what's the point in spending money I don't have to spend on a monitor better than my eyes?
    Bloody_Pete likes this.
  6. RedFlames
    23 Apr 2009
    For the same reason you bought a calibration widget... so you know for sure it's your eyes that are screwy, not the monitor.?
  7. Fingers66
    30 Apr 2010
    If the price is too much, look at the U2717D which is the previous model and significantly cheaper (as linked by @edzieba ). Review here: https://www.tftcentral.co.uk/reviews/dell_u2717d.htm
    8ms GtG is the rough norm for 60MHz IPS panels.
    I was focussing more on the sRGB calibration and "real work" quality rather than gaming elements.
  8. Gareth Halfacree
    4 Dec 2007
    Still £322, though.
    Looking at the detailed specs, and assuming DisplaySpecifications is actually on the money, the Iiyama beats either of the Dells in sRGB coverage, response time, and input lag, and is cheaper to boot. All these monitors are 8-bit panels, too (again, according to DisplaySpecifications), with the three none-Dells offering 10-bit support via FRC while the Dell is eight-bit-is-yer-lot.
    Going purely by the numbers, the Iiyama looks to be the one to beat.
    EDIT:
    Helpfully(!), this thread has one guy saying "the Iiyama's a pile of crap, I sent it back" and another saying "really impressed with the image quality." Was the first one unlucky, or the second lucky? Agh!
  9. RedFlames
    23 Apr 2009
    Of the 3 in your OP i'd go for the BenQ. Partly because my experiences with iiyama's offerings have been... not great...
    Gareth Halfacree likes this.
  10. RedFlames
    23 Apr 2009
    You'll find that with a lot of monitors, including the dells.
    FWIW my experience with them was 'crapped out after just over a year' and out of the box default settings so bad not even the shonkiest of eyes would need a spyder or similar to go 'something is clearly not right here'.
    The BenQ isn't factory calibrated either but out of the box they're usually ok, and iirc they can suffer from uneven backlight, but if you read reviews so can every other monitor under the sun.
  11. edzieba
    14 Jan 2009
  12. RedFlames
    23 Apr 2009
    ...also the 1st rule of buying dell monitors... is *never* buy them direct from dell.
  13. adidan
    25 Mar 2009
    * Looks at sig *
    Love it.
    Only game at 1440p though and have no calibration tools but i love it. If i can find them i'll hunt down the positive reviews i found about it, took a while to decide - didn't buy on a whim.
    Edit: actually the review i was thinking of was that wecravegames link in that thread which doesn't seem to exist anymore. Shame.
    I also wonder if it depends where you get it from, mine was from Scan and has been great.
  14. Fingers66
    30 Apr 2010
    I think Gareth only tends to buy through Amazon (or has vouchers/discounts).
    Anyway @Gareth Halfacree , I'm assuming this will be a business expense won't it? It certainly meets all the criteria.
  15. Gareth Halfacree
    4 Dec 2007
    Nah, I'll buy from wherever's cheapest. I just tend to use Amazon for general pricing searches, user reviews, and to link to, 'cos everything's there: once I know what I want, I'll DuckDuckGo to find where to actually buy it. (Case in point: saved myself £20 on the Colormunki Display colorimeter I just bought by getting it from Wex instead of Amazon.)
    It will, but I am the business. All marking it as a business expense means is that I get to shove it in the "loss" column of the P&L for tax purposes. I'm not VAT registered, so I can't claim VAT back - hence using the after-VAT pricing from Dell Business for comparison.
    Almost certainly!
  16. adidan
    25 Mar 2009
  17. Gareth Halfacree
    4 Dec 2007
    I hadn't - I'll check it out, ta!
    EDIT:
    Put me off a bit, that. "The color error of the XUB2792QSU-B1 is on the high side, at least for this class. We measure 3.75 based on CIE2000, which is just over the limit of 3 that we hold as 'visible to the naked eye'. The standard deviation is also on the high side compared to the competitors. The XUB2792QSU-B1 does not have a separate sRGB mode, so we were unable to test it either. There are various modes (standard, game, cinema, landscape, text) and there are limited possibilities to adjust the color temperature and color settings, but it is clear that this screen is not primarily intended for image editing."
    I like the thought of FreeSync, though, and it's likely to be better than what I have now, and maybe the colours could be corrected with the shiny new colorimeter I'm getting...
  18. RedFlames
    23 Apr 2009
    Stop being all yorkshireman and tight and trying to convince yourself the el-cheapo option is the best one... ;)
  19. Fingers66
    30 Apr 2010
    This, a million times this!
  20. adidan
    25 Mar 2009
    It ain't, or at least wasn't, el cheapo - was 330-340 iirc a year or so back.
    Well i wouldn't call it el cheapo but then i have some Yorkshire blood too - if it ain't free it's pricey and even then i have to think about it. :)
    Edit: Yeah there's pluses and minuses aye but i think there's plenty of positives in the review. Depends on your needs. I wish that other link was still active, i remember it being thorough and tweaked up well. I was considering a Dell at the time, which was a worse performer - for me anyway but like i say different horses, different courses.
