Linux Problem mounting Vista shares
Discussion in 'Software' started by DougEdey, 16 May 2007.
  1. DougEdey
    5 Jul 2005
    I seem to have difficulties mounting shared folder with a total size >2GB in Gentoo.
    Whenever I try to mount using SMBFS it mounts, but then says "Permission denied", using CIFS it says "Error 20: directory does not exist"
    If I mount a folder shared on the Vista machine < 2GB it works fine.
    this reccomend to use lfs as an -o value, but it causes the same problem.
    Any ideas?
    2.6.20-r7 gentoo kernel, connecting wirelessly to a Vista Business machine.
  2. afen
    afen cyb0r p1mp
    10 Aug 2001
    mount -t smbfs -o username=***,password=*** //vista/share /mnt/share
    Have you tried that?
  3. DougEdey
    5 Jul 2005
    thats the way I get the permission denied error.
  4. afen
    afen cyb0r p1mp
    10 Aug 2001
    Tried mounting as root? Correct password? Correct permissions on the share? On the mount dir?
  5. DougEdey
    5 Jul 2005
    yerp, all checked. If I mount anything which is lower then 2GB it's fine.
  6. Glider
    Glider /dev/null
    2 Aug 2005
    try:
    Code:
    mount -t cifs //vista/share /mnt/share
    EDIT: I should read before I post ;)
  7. DougEdey
    5 Jul 2005
    there may be a problem with SAMBA/CIFS. I can see the laptop from Windows but when I goto a share it says "Windows Cannot Access ..." "The network path was not found"
    And with the laptop if I type the PC name it can't find it, but it can find the IP
  8. Glider
    Glider /dev/null
    2 Aug 2005
    That's a different problem (DNS). If you add the IP of your Vista pc in /etc/hosts then it will work ;)
  9. DougEdey
    5 Jul 2005
    DNS problem is solved and so is the share
    Vista decided to remove global access for all my shares when I added a new Hard Drive.
