PSU problem powering 6 hard-drives.
Discussion in 'Tech Support' started by Foog, 21 Oct 2009.
  1. Foog
    Foog What's a Dremel?
    21 Oct 2009
    Hi
    I've been a long time reader first time poster.
    the problem im having at the moment, is that my server keeps freezing at mup.sys during boot, i've troubleshooted it down to ONE specific issue, and that's insufficient power to my hard-drives in my server.
    I know this is a pretty standard problem, and many many people forget about it. BUT! I'm trying to avoid buying a new power-supply since the one i have in there is pretty big already and there shouldn't be THAT much draw. My spec's are as follows:
    Atom 1.6GHz CPU
    3x 1TB EcoGreen (5400rpm) drives / one is a WD the other two are SAMSUNG
    Silicon Image 3152(?) 2x port RAID card.
    1x 320GB (7200rpm) drive
    1x 500GB (IDE -7200rpm) drive
    1x 160 (IDE- 7200rpm) drive
    What im trying to achieve is to stop the RAID card from booting those drives until the others are spun-up. Since I hear a whirrr from all of the drives and then it reboots.
    OR
    Is it possible that I have plugged the drives in incorrectly? I have daisy chained one off another on the one cable. Could it be only ONE cable that has insufficient amps? What is recommended to connect drives to a power-supply? Try and spread them out as evenly as possible? Which drives do you think draw the most power?
    OR
    Is this something unrelated? I've run chkdsk on all the drives, and there are no problems there. My current solution to get it booting was removing the two 1TB (5400rpm) drives. Also the version of windows is NOT corrupt. Since it's a fresh install with no problems, and no applications have been installed.
    Any help is greatly appreciated. Thankyou. :)
  2. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    what power supply are you using?
    i don't think that you can delay spin up on SATA drives.
    i know that SCSI stuff usually doesn't spin up till the card's bios loads but not seen it with SATA.
  3. Foog
    21 Oct 2009
    Codgen 650W 12V ATX
    Have I missed something?.. It was working before until I replugged a connector in that was partially out of a 1TB drive, because the 2nd drive of my raid kept dropping randomly... Hence why i think it's a power supply issue. Since it boots but the moment those drives spin up.. It dies.
    failing at mup.sys is a fairly common issue, so i've disabled USB etc in the BIOS and investigated all the things that could cause it. but the moment i plug my drive back in and it goes into the reboot cycle failing at the same point. I've rotated the drives and the cables, it just seems the moment anything else is connected it dies.
  4. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    How did you connect those cables?
    Hoe much rails has the PSU?
  5. Foog
    21 Oct 2009
    I dont know anything about 'rails' i'll wikipedia it.
    The drives are connected in the following
    1TB + 320GB = 2 sata connectors from the PSU
    2 IDE drives are connected to ONE molex strand comming off the PSU
    the 2 other drives (the ones that cause the problem) are connected by 4pin to sata connectors attached to another strand seperate from the 2 IDE drives.
    should i try and switch up the 2 sata connectors on the PSU to the two drives that cause the problem? (the drives arn't faulty) and leave the IDE ones on their own and use the 4pin to sata connectors on the other two drives?
  6. identikit
    identikit Minimodder
    5 Jun 2004
    I've seen a few SATA RAID cards with staggered spin up. My advice OP, get a new (decent PSU), ditch the IDE drives in favour of another 1TB and get a better 4-port RAID card.
  7. Foog
    21 Oct 2009
    sounds like a good idea.. i might ditch the IDE's altogether today.. It's only 600gb
    NEW SYMPTOM: So, after switching around some cables i managed to get a ntfs.sys blue-screen as the two 1TB drives (brand new) are powering up. Anyone got any idea's?
  8. B3CK
    B3CK Minimodder
    14 Jun 2004
    Look at your bios, for the raid card. You should see it directly after/before your normal bios post. Inside there, depending on model, you can set a delay or staggered spinup of the drives. Mine has it, at least.
  9. B3CK
    B3CK Minimodder
    14 Jun 2004
    Try running a live cd like Hiren or ultimate boot; and run a disc check, could also use a windows disc and do it through the repair console.
  10. Kougar
    Kougar What's a Dremel?
    19 Aug 2008
    As B3CK said your RAID card's BIOS should allow you to change the drive startup setting, I'd be surprised if it did not.
    Also I'm not sure what server board you have, but my Gigabyte X58 board has a BIOS setting to delay HDD initialization from 0-15 seconds under the Advanced BIOS Features section.
    Just a guess as far as the BSoD, did you disable or forget to renable AHCI mode?? Changing drives around may have changed the boot order of the drives in the BIOS too, had that happen to me where it tried to boot off of a secondary drive with an old Windows install left on it instead of the one I just newly installed for the new build.
  11. dark_avenger
    9 Jul 2008
    news to me....
    *runs off to check sata raid cards*
  12. Foog
    21 Oct 2009
    Sadly not in this case, there's no settings for it. It's a cheapie raid card, which may potentially be the problem but at the moment i've isolated it to the power supply either it be cables or the PSU itself.
    All this is correct, i've gone through the BIOS restored defaults. changed settings to no avail.
    Are you thinking the 1TB's on the raid card could be corrupt? and they are causing the blue-screen when windows tries to load them?
    I might just throw this out there, but that's my first guess on this blue-screen.. The drives have been ruffled abit during trying to test this problem their corrupt. Any merit to this?
    Still looking for suggestions and would be willing to try absolutely anything to get this working... I'll replace the cables connecting the HD's to the raid card this weekend they are molex to sata connectors. Anyone had an experience with these being crap?
  13. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    No idea about your BSODs but i'd just like to say that Codegen power supplies have a terrible horrible reputation so i wouldn't use it in a server, of all things. Even though you'd hardly put any load on it with that setup.
  14. Kougar
    19 Aug 2008
    So this is a Codegen PSU? Foog, what's the model/name of the thing?
    Unless you changed something on the drives themselves it shouldn't have broken the RAID array! Of course that's a "shouldn't" though, I've had to many issues with my past attempts with RAID arrays to rule it out.
