well i poked around on the evga website knowledge base and i found out that that it could be artifacting from a psu not giveing it power found somewhere here http://www.evga.com/Support/KnowledgeBase/default.asp?search_switch=2&page=2 and when i do get my new neopower psu and it happens ill just give then a nice call to get a new gpu thanks guys for all your help u can just read this u dont have to reply now i just have to get working on ordering! any1 know some good ummm UV cable messhing i though that would be cool if not any will do and what is better ties or mesh? how fking ironic found on evga: Topic I get frequent lockups in games, where the screen will go black or freeze and I will get stuttering music in the background. Article The IRQ channel that is assigned for sound cards get might be the same IRQ channel as the Video card which will lead to problems. There might be problems with an excessive amount of data going across the PCI bus and that causes a problem - or it might be that you need to try the latest drivers for the sound cards. Another possibility is DirectX's preference for digital certification of these sound card drivers. You can also try relocating that sound card into a different PCI slot. ok how do i change irq's someone give me a tutorial just in case plz
OT: Will you please stop creating a new thread instead of just replying to the main threads you've already created regarding the same problem 2 seconds with google brought up all these results.
Glad its finally solved lol! Seems like it IS the psu as said in your last thread. Though as _H_ said, it'd be best to keep things to 1 thread, not only to reduce clutter but if others have the same problem its a PITA for them to find out how you resolved it!
k well 1 Q if i disable or change ACPI will reinstalling bring it back???? how do i disable this so i can change irqs? ok i know that update driver on he acpi will let me play with it if al goes to plan i should be able to ajust irq's but what is the down side what will i lose?
