Problem with CPU E6600
Discussion in 'Hardware' started by Fullmetal, 11 Sep 2006.
  1. Fullmetal
    Fullmetal What's a Dremel?
    10 Sep 2006
    Hello,
    i have a C2D e6600 with sunbeamtech heatsink/fan, an intel 975xbx, 1gb corsair 675 ddr2 XMS, 7900GTX
    i cant get in the bios to overclock the processor, i can get in the bios, but their is no feature to let me overclock.
    i heard that this motherboard is great overclocker,
    and also, my e6600 idle 43 C, is that good, shouldnt it be lower.
    THank you
  2. Super_Crazy_Guy
    Super_Crazy_Guy What's a Dremel?
    6 Sep 2006
    Thats not a very good choice in motherboard, does this even support core 2 duo fully? i would totaly check. but i dont think this board was made for core 2 duo.
  3. Guest-16
    Guest-16 Guest
    The Intel XBX bad axe board does support C2D (blue heatsinks, not yellow on VRMs).
    Uh, I cannot remember off the top of my head where the overclocking options are. It's only recently that Intel has allowed ocing on their boards and im almost certain the Bad Axe does, try and get an updated BIOS from Intel's site.
    There should be an option called frequency control (iirc) under advanced options, perhaps. I havent got the board to hand so I cant check, sorry.
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    The intel boards tend to have limited options, but there should be a few (FSB/Strap/VID/Vdimm etc) available afaik.
    Have a scan over this
    over at XS.
    The board overclocks ok, but you really need vmods to make it shine. The bios options are somewhat limited. Temp wise, 43 idle seems a touch high how hot is the heatsink?
  5. Fullmetal
    10 Sep 2006
    the heatsink isnt very hot at all, rather, its very cool, which is odd
    thx highlander....great help, much appreciated..but i suck with solder, i will try however, when it says however " conroe support ", do i have to do that, or since my conroe works fine, i wouldnt have to?
    also, will intel ever do a realease just unlock the full bios....is it possible.
  6. Highland3r
    25 Jul 2003
    Afaik the conroe support bit is only for some of the earlier rev boards. The bios unlock (if you don't already have the options) should work fine tho.
    The options available are enough to allow fairly decent overclocking. What you can't do from in bios you can do in windows via Clockgen and Memset
  7. Fullmetal
    10 Sep 2006
    thx so MUCH...i love u man, i was looking for a program taht is overclocking within windows rather than outside....in bios....much appreciated
  8. Fullmetal
    10 Sep 2006
    err....i dotn know how to use clock gen, my mobo isnt present....under what ICS family would it be....
