Notebooks problem with dvd drive (new laptop)
Discussion in 'Hardware' started by kill_me_quick, 31 Mar 2006.
  1. kill_me_quick
    kill_me_quick Big and Blue
    7 Jan 2004
    Just bought a laptop, booted fine and went to install a program.
    When I got into my computer there was no dvd drive shown, nor in device manager. Went into the bios and there is no drive showing.
    Could this be a problem that the drive isnt connected or just a software fault.
    Obviously they have to install windows using the cd drive so it must have worked then.
    Many thanks
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    My mate had the exact same problem, turns out it was a design flaw, and you had to pust the drive further into the bay to make the connection, and then reboot so it would recognise it.
    Give it a shot, it might be what's happening to yours.
    I'm assuming it's still under warranty?
    Edit:
    IIRC a lot of companies just pre-load straight to the HDD before installing it, so it could have been missed.
  3. kill_me_quick
    7 Jan 2004
    Ill give that a go, it might work.
    Yeah its still under warrenty I got it just over an hour ago, although the "VOID" sticker is a little bit "scratched"
  4. kill_me_quick
    7 Jan 2004
    Cheers mate, that just worked. Have an eBeer on me
