Graphics Problem with DVD
Discussion in 'Hardware' started by sinizterguy, 22 Oct 2003.
  1. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Running windows 2003 server (converted to workstation) and latest updates.
    Abit Siluro FX5200 (passively cooled) with latest dets.
    Whenever I play a DVD, all I can see on screen is a white block, nothing else.
    Anyone know why this could be and what I can do to fix it ?
  2. MR BUNGLE
    MR BUNGLE Shoddymodder
    19 May 2003
    What software are you using for the DVDs...?
    - Could be any number of things I suppose....
    Check that full hardware acceleration is selected in windows>performance options...
    - Also check that your DVD software has Hardware Acceleration enabled...
    Other than that, could be dodgy Mpeg2 codecs (or lack of one).....
  3. sinizterguy
    25 Jul 2002
    I clocked down the processor from 2.8 GHz to 2.7 GHz (FSB from 156 to 150) and it went away.
    Everything works fine now.
    Time for a mobo upgrade me thinks.
