I have just updated by only 32bit machine to 64bit and when i went to start folding again i keep getting this message: + Could not get ID from server. Retrying... [09:37:52] + Could not connect to Primary Assignment Server for ID [09:37:52] + Could not connect to Secondary Assignment Server for ID any suggestions
Can you ping the Stanford Assignment servers from the folding rig? Try running these commands in a command prompt: Code: tracert assign.stanford.edu tracert assign2.stanford.edu tracert 171.65.103.93 tracert 171.64.65.121 Do they work? Also, try opening these in your browser: http://www.stanford.edu http://assign2.stanford.edu http://assign.stanford.edu:8080 You should just see "OK" in the browser window for the last 2. Also, what anti-virus package is on the rig?
Cheers guys for your responses: Ph4lanx - All tests passed saspro - ports 80 and 8080 are open. its weird because i have a machine next to this one which is send and receiving work correctly. P.S i'm on linux so windows based solution will not work, I have seen the various IE suggestions and AVG
Do you run a proxy or anything like that? Is perhaps the proxy accidentally set in the client.cfg or something? You're not trying to run bigadv are you?
Fixed it. Thread: http://foldingforum.org/viewtopic.php?f=44&t=13064&p=145633#p145633 helped I had turned off nscd, Enabled it and bang it could contact the server again. My distro is fedora 12 hopefully google will index this for future generations
mines done the same... [15:14:28] Folding@home Core Shutdown: FINISHED_UNIT [15:14:30] CoreStatus = 64 (100) [15:14:30] Sending work to server [15:14:30] Project: 6701 (Run 21, Clone 16, Gen 38) [15:14:30] + Attempting to send results [October 1 15:14:30 UTC] [15:18:30] - Couldn't send HTTP request to server [15:18:30] + Could not connect to Work Server (results) [15:18:30] (171.64.65.56:8080) [15:18:30] + Retrying using alternative port Folding@Home Client Shutdown at user request. Folding@Home Client Shutdown. its been folding this unit since 0130hrs and no reward for it, working on new unit now
