Windows Problem with GTA Vice City
Discussion in 'Software' started by sinizterguy, 14 Oct 2003.
  1. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    When GTA Vice City, it always crashes after a specific amount of time.
    Running Windows 2003 Server (converted to workstation)
    P4 2.4B @ 2.8 (Watercooled)
    256MB DDR333 Crucial (Slower than stock)
    Abit Siluro FX5200
    I think it might be the graphics card. Its passively cooled with the stock Abit heatsink. And the heatsink even during normal running gets really HOT as in you cant keep your finger on it for more than 2-3 seconds.
    Any suggestions ?
  2. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    uhhh... stick a fan on the gfx card and see if it still crashes?? seems pretty obvious to me...
  3. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    Unhandled exception error? Everyone I know (including me) seems to be getting these after installing the latest MultiTheftAuto.
  4. sinizterguy
    25 Jul 2002
    It just locks up and audio keeps looping. Doesnt respond. I have to reset the machine.
  5. Foolio882
    Foolio882 What's a Dremel?
    1 Sep 2003
    I get the same problem in BF1942 and SoF2, let me know if you can figureit out, because I sure as **** can't!
  6. NiHiLiST
    18 Aug 2001
    It does sound a lot like your graphics card is overheating.
  7. Darv
    Darv Bling!!
    12 Aug 2002
    I had this problem with all of my 3D games. The game crashed but the audio kept playing and I had to reset it. Turned out it was because I had the FSB at 200mhz. It was fine in windows but crashed after a few mins in games.
  8. Foolio882
    1 Sep 2003
    SO you had a low multiplier and a high FSB set for your proc? I'm gonna try underclocking both my prac and the card and see what that does, THANKS! :thumb:
  9. Rich_13
    Rich_13 What's a Dremel?
    12 Feb 2003
    if urs was a stock though thats shouldn't effect it. only when o/c'ing
  10. tk421
    tk421 Idiot.
    15 Jan 2002
    i found that setting my ram timings back to the corsair spec's kept me from getting UE's in Tribes2 ...
    i had cranked it down to CL to 2, when i went back to 2.5 all was well ...
