Problem with MP3 Player
Discussion in 'Tech Support' started by D1662, 1 Jul 2006.
  1. D1662
    D1662 What's a Dremel?
    26 Nov 2005
    :wallbash: A friend of mine purchased from Spain a "Sanyo HDD Audio Player HDP-M3000" and I have tried it on my desk top PC which has windows XP Home edition, and I have tried it on my lap top which has Windows ME, and the player is not recognized on either systems. :wallbash:
    I am just wondering if the player is not compatible with UK systems, or could there be a fault in the USB cable.
    If there is any useful information to correct the problem out there in cyberland would be gratefully received.
    Link to picture off MP3 Player.
    :thumb: http://www.macavoyt.freeserve.co.uk/Sanyo_HDP-M3000_Silver.jpg :thumb:
    Regards.
    Terry Macavoy
  2. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    Have you checked to see if it needs a driver or special software installed with it? Though tbh i think it sounds more of a hardware problem as windows should still notice it.
    plus i believe this to be in the wrong forum. A mod should be able to move it for you
    edit: better
  3. D1662
    26 Nov 2005
    MP3 Player Problem
    :thumb: As far I can work out the drivers and other software in loaded in to the player which in my book makes plug and play. :thumb:
    Please follow this link to view the instruction book.
    :wallbash: http://www.macavoyt.freeserve.co.uk/597649.pdf :wallbash:
    At the moment it is plugged in to PC and the display is showing a picture off a watch and the word "WAITING" underneath it
    :duh: How do I go about getting this post moved. :duh:
    Terry.
  4. TheoGeo
    10 Jun 2003
    its been moved already.
    I cant really look at the manual at the moment since the pc im on is a load of crap, i'll have to wait untill i get home on monday.
    The player is clearly detecting the connection but windows isnt. try going into device manager and seeing if it is there.
    right click my computer>properties>hardware>device manager
    See if there are any items in there with exclamation marks on them, if there are try updating drivers for them.
  5. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    I'm pretty sure with sony mp3 players, you need their software installed.
  6. furqan
    furqan What's a Dremel?
    2 May 2004
    he's got a Sanyo not Sony ;)
    this person's having a similair problem http://forums.techguy.org/multimedia/428107-sanyo-mp3-player-big-problems.html
    so it might be worth trying this:
    Create a file with NOTEPAD containing the following lines and save it as FIX.REG
    -------------------------- cut after this line --------------------------------
    REGEDIT4
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment]
    "DEVMGR_SHOW_NONPRESENT_DEVICES"="1"
    -------------------------- cut before this line--------------------------------
    Double click on FIX.REG and say yes to the Merge Into Registry question.
    Unplug ALL USB devices.
    Open Device Manager.
    View, Show Hidden Devices.
    Uninstall all devices under USB Controllers.
    Uninstall all devices under Disk Drives that you know are not present.
    Uninstall all devices under Storage Volumes. Say no to any reboot prompts until you are finished. Also, if a Storage Volume doesn't uninstall, ignore it and move to the next one.
    If you have a yellow ? with unknown devices, uninstall all of the entries there as well.
    When this is done, reboot TWICE.
    Reconnect the USB devices and see if they're recognized properly.
  7. Sam0r
    24 Jun 2005
    My bad, read it as sony. Move on.
  8. D1662
    26 Nov 2005
    Problem with MP3 Player.
    :read:
    :confused: When you say "disconnect USB devices" or do you mean mean just game pads printers etc etc............... just double checking to make sure I get it right first time. :confused:
    Terry.
  9. DougEdey
    5 Jul 2005
    ALL USB devices, thats EVERYTHING
  10. D1662
    26 Nov 2005
    :confused:
    :confused:
    :jawdrop: Even the wireless key board and mouse :jawdrop:
    Terry
  11. DougEdey
    5 Jul 2005
    Yes, you'll need to find a standard keyboard and/or mouse, so a Serial mouse and/or AT/Ps2 mouse.
    And please don't overdo the punctuation, it annoys people.
  12. D1662
    26 Nov 2005
    Thats a turn up for the books
    Sunday 02 July 2006
    Update on this problem, the aforementioned item has been plugged in to PC for over 2 Hours and this is as far as it has got.
    Please follow this link.
    :idea: http://www.macavoyt.freeserve.co.uk/PDR_0005.AVI Thank you. :idea:
    Item has been unplugged for now until further advise has been sort.
    :eyebrow: I suffer from dyslexia so I tend to Spell check everything that I type. :eyebrow:
    Apologies if it annoys anyone.!!!!
  13. DougEdey
    5 Jul 2005
    For the punctuation I referred to your subject of your previous post.
    Have you tried what has been reccomended? I.e. the registry and/or looking for drivers?
  14. D1662
    26 Nov 2005
    Re MP3 Player
    :nono: After a lot off thought I have decided to send the offending item back to Sanyo, as I a feeling that there is no battery in it, as it has been on charge for over 10 hours and it still will not switch on, as mentioned in previous links that were listed all that shows up is the watch face and waiting is displayed. :nono:
    Thank You
    Terry Macavoy.
