Hello! I formated my hard drive and re installed windows xp. And now i have a problem. The windows update wont install updates. He gives me a window and says that updates cant be installed. Could anybody help me? Sorry for bad english
Run services.msc from Start>Run. Stop the Background Intelligent Transfer Service and Automatic Update services. Then delete the Software Distribution folder in c:/windows. Go into Internet Options in the Control Panel and select the Security tab. Add the following sites to the Trusted Sites list (by clicking on the Sites button): http://*.update.microsoft.com https://*.update.microsoft.com http://*.windowsupdate.microsoft.com https://*.windowsupdate.microsoft.com OK it and close Control Panel, then try doing an update again. This is a very basic fix for the most common problem I've found. It may not work. The first result in Google brought this page up: http://www.updatexp.com/windows-update-errors.html - may very well help you.
Nope, you just can't install any other than critical hotfixes. This is at least in Vista and XPSP3, dunno about XPSP2.
